From seeing over the past year or so people purchasing the inexpensive portable air booths, and getting hit with expensive filter replacements, I decided to find an alternative.
This may apply to the expensive large table top versions too.
http://www.tcpglobal.com/Airbrushing-Su ... ray-Booth/
As you may know, the replacement filters are $10 each, and at least for me get pretty dirty pretty fast.
As of now I cut regular, furnace filter to size to protect the factory filters, but this does not last long either, it does prolong the life, and if I changed it out more often would preserve it indefinitely.
However, I wanted a long term solution without having to jerry rig an air filter .
So I found this roll of filter, that all I have to do is make one cut, and pop it in.
So instead of $10 each, they should come to about .25$ each.
I am not a numbers guy and this is all theoretical, does anyone else do this, and does any one see a flaw before I order.
The roll is 16"-85' (1,020") by 1 inch thick. $32 for 136 filters .25 each
Current filter is 16"-7.25" by 7/8" thick, $10 each
One of you big brains check my numbers please.
