http://www.bronco-model.com/en/productsd.php?pid=171
So it seems I feel into a bit of a artillery spotter rut.
All the stowage is aftermarket. The figure is from a TriStar crew kit.
The kit:
The kit includes 3 different fronts for the hull. The instructions clearly tell you to use the wrong one, I didn't find out until the glue was dry, lots of cutting, sanding and cursing was needed to put it right, even then the proper driver's hatch was lost in my rage, another one had to be sanded done to fit (the view port is on the wrong side of the hatch, but if you care then you can fix it for me
The muffler and it's supports are just "eye-balled" into place, the actual mounting point is in no way marked or indicated. The instructions also have you do this during the lower hull assembly. Later, when you add the upper hull you find that one of the exhaust pipes is supposed to contact the upper hull, but at that point you've probably mounted it in the wrong spot. If you do build this kit, leave the muffler and mounts off until you have the upper and lower hulls together.
I added the wire frame for the fuel can rack, the model needs extra details added.
That aside I like it, another very small AFV. Also it's another German vehicle built on a captured French hull.
