vallejo primer problem
hi guys
i have a bit of a problem or question regarding the vallejo primers
i have 2 of them at the moment the black and the grey
and i use a airbrush to apply them and here i have 2 aswell
i use a h&s evolution and a cheap one of wich i don't remember the brand
now the point is that i was being a idiot and i put the primer in the evo
the black primer that is and this worked out just fine
altough.it was a bit of a pain to clean the airbrush but then i used the grey and it clogged the.nozzle in about 2 seconds so the big question is how to avoid this
i used the black primer again this time in the cheap airbrush wich is easyer to clean aswell so this now gets the job
but i don't understand what caused this and should i keep the grey primer
so ig you know please lend me a hand
thanks for your time
cheers Mark
Matthew
Re: vallejo primer problem
Post by Matthew »
Are both of the airbrush needles the same size
Matthew
Post by Matthew »
I have never used this primer but some times I still have to had a bit of thinner even for airbrush ready paint dude
thanks that could be the solution that it is just to thick
and now that you mentioned it
the nozzles aren't the same size the evo is a .2 and the other a .3
so i have someting to work with
cheers Mark
Get your self some ak/ammo primer and you wont have this problem, vallejo primer can just be too finicky to ab and with the risk of peeling and pulling off when sanding and masking, ak/ammo primer is much more reliable.
Paul wrote:Get your self some ak/ammo primer and you wont have this problem, vallejo primer can just be too finicky to ab and with the risk of peeling and pulling off when sanding and masking, ak/ammo primer is much more reliable.
i'll go and look for the ak primers
give them a try too bad no shop i know have it but.i'm sureni can get some
thanks Paul
thanks Paul
Well worth it mark :thumb2:
Matthew
Post by Matthew »
Yes have been useing the ak primer love the stuff now I'm I right in thinking ammo will be the same Paul ?
Matthew wrote:Yes have been useing the ak primer love the stuff now I'm I right in thinking ammo will be the same Paul ?
It is mate I've got a bottle of each :thumb2:
Matthew
Post by Matthew »
:cheers2: :thumb1:
you know,you people are a very bad influence too me lol
you suggested i should use ak primers
and if you say so i believe you
so now i want ak primers
wich is going to cost money ofcourse
so gentlemen my wallet does not thank you
i do thank you for your time.and knowledge
and i talked to a buddy of mine and he said he has a spare bottle of ak primer that i can use to test it for my self
cheers Mark
MarkVerploeg wrote:you know,you people are a very bad influence too me lol
cheers Mark
Im sorry Mark :tongue: least you get to try a bottle to test :thumb2:
you don't have to say sorry for it
and i will see how it goes with the ak stuff
and then i look at some shops who sells it in the netherlands
just to keep shippingtime to a minimum
cheers Mark
and the problem is solved.
i just did a testrun on one of sides of my big tiger
and this ak primer i got from my buddy sprayed on great
i had no problems with it,just like normal paint
so once again thank you for the help
cheers Mark
peppie
Post by peppie »
Hi Mark,
Do you already know where to get it in the Netherlands?
I also want to try it.
Thanks
Peter
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
peppie wrote:Hi Mark,
Thanks
Peter
i think you mean me with this
and no i don't know who has it overhere but i ordered it from sockelshop in germany
but now that i think of it dax magic may have it aswell but i'll have to check that
peppie
Post by peppie »
Yep, I ment you (hi Mark....)
Allready checked Daxmagic, no primer.
Postage not to bad with the Sockelshop then?
Oh, and before I forget: can you use Vallejo ab cleaner with this?
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
peppie wrote:Yep, I ment you (hi Mark....)
postage depends on yhe total amount of the purchase as with most dealers
but i order several things at a time and that gets me to pay 100-150 euro so postage is a small amount then or free
but postage still beats driving there my self
as for the cleaner it did work when i tested it but that was a small amount as.it was a borrowed bottle of primer
but just to make sure i got me some ak cleaner aswell (plus where i ordered the cleaner they ran out of vallejo cleaner)
but i will have to get back to you about that as all the stuff i bought comes in during this week
cheers Mark
peppie
Post by peppie »
Thanks Mark,
Off course I can also order the AK cleaner, but then what does this do with the Vallejo paint?
Trying to keep it simple with all the different cleaners and thinners.
Btw, I just found it here
http://www.plasticmodelbouw.nl/product_ ... aefc34d87a
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
peppie wrote:Thanks Mark,
Ultimate thinner and cleaner :thumb2: www.umpretail.com
peppie
Post by peppie »
Can this be used with all acryllic paints?
Even paints like Tamiya (alcohol based I think)?
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
peppie wrote:Can this be used with all acryllic paints?
the people at Ultimate (Lee and Paul) make it to go with all acryllic paints
but i don't have that
as for the site you posted , i forgot about them it used to be the shop from Mol modelbouw but he stopped and a belgium company took over
they messed things up in my opinion with.things like payment and the site in general wich was easy to find things
and when mol didn't have things in stock he would order them for you
i didn't had that service after he quit as i got a mail saying that the things i was looking for where not in the assortment and thus not availible at all
but that was a few years back and they could have changed
but i kind of like the german shops as they have better prices and the sales sections offer real bargains
so i use their shops in stead
It works with every acrylic paint out there, i tested them all personally. :cheers2:
