No window
conradschmid99
No window
Post by conradschmid99 »
I'm setting up my spray booth when I realize that the window next to it doesn't open... non of them do :crazy:
Where do I put the hose :roll:
-unknown
conradschmid99
Re: No window
anything? :shifty:
-unknown
Re: No window
If the booth has a filter in it and your using acrylics you could just run it without the hose.
Other wise we'd need to know more to come up with options, unfinished basement? Use another window? Longer hose?
Re: No window
Get a core drill and make a hole, depending on wall type, it'll only take an hour or so.
Re: No window
chief5437 wrote:Get a core drill and make a hole, depending on wall type, it'll only take an hour or so.
Chiefs got it right, it can be hard work, but they are fairly cheap to hire and its the best solution.
Spraying into the booth filter may well catch most of the paint particles, but you still have the paints solvent fumes floating about the place and they will soon have an effect on you, not good for your health at all
conradschmid99
Re: No window
The only thing wrong with that is that I live in a rental house and I'm not allowed to drill any holes!
-unknown
Re: No window
Does the room have an existing extractor fan that you can put the hose up against?
I guess the rental regulations in Texas are different to the UK as here all windows have to open in a rental house.
Re: No window
Tell them it was already there, lol!
Switcher
Re: No window
Post by Switcher »
DC87 wrote:Does the room have an existing extractor fan that you can put the hose up against?
Exactly! It is law regardless which country. All windows need to be operational in case of egress. Get a hold of your landlord and get him/her to unstick them. If he refuses file a complaint with the tenancy board.
On my desk:
1/350 Alpha Class Sub (Russian)
1/350 Akula Class sub (Russian)
1/350 USS Missouri USN Battleship BB-63
Re: No window
Or use a brick.
conradschmid99
Re: No window
I don't want to get into any trouble with the land lord...
would something like this work as an alternative?
-unknown
Re: No window
conradschmid99 wrote:I don't want to get into any trouble with the land lord...
Nope :(
conradschmid99
Re: No window
why not?
-unknown
Re: No window
conradschmid99 wrote:why not?
Because its made to dissipate solder fumes not extract paints fumes and particles
Switcher
Re: No window
Post by Switcher »
Because you are back to square one with that. e.g not extracting the nauseous/toxic fumes.
I understand not wanting to PO your landlord, but then again the windows should not be stuck. If it a small pane, replace it with plywood with a hole cut into to fit your exhaust hose, with the understanding that you intend to replace the pane before moving out.
The other option is to only use acrylics, and wear a face mask when spraying, which you should be doing anyway.
On my desk:
Re: No window
How far is the distance to another room with a window that can open as buying some DIY store tubing and sealing it to the spray booth hose must be an option?
conradschmid99
Re: No window
DC87 wrote:How far is the distance to another room with a window that can open as buying some DIY store tubing and sealing it to the spray booth hose must be an option?
none of the windows open
I guess I could run a hose to the back door, or paint outside.
-unknown
Re: No window
Hose to the back door would seem the best option.
Re: No window
None of the windows open?! Wow, I guess safety is a dirty word in the US!
