Tamiya 1:48 Raiden (Jack)
I will be building a Raiden.
Stay tuned for more information...
Re: Tamiya 1:48 Raiden (Jack)
Specifications
ManufacturerMitsubishi Heavy Industries
Year1943
ModelJ2M3 Raiden
Allied Code NameJack
Crew1
Max T/O Weight8,699 lb.
Span35 ft. 5 in.
Length31 ft. 9 in.
Height12 ft. 6 in.
Maximum Speed407 mph
Cruise Speed228 mph
Rate of Climb3,838 ft/min
Power Plant1 x Mitsubishi MK4R-A Kasei23a 14-cylinder air-cooled radial engine, 1,820 hp.
Range656 mi
Service Ceiling36,080 ft.
ArmamentFour Type 99 20-mm cannon
History
planesoffame.org wrote:
  • Design of the J2M Raiden (Lightning Bolt) began in 1938. But almost five years passed before The Imperial Japanese Navy issued a request for a land-based interceptor, for which the Raiden (Allied code name Jack) was suited. It was the first time the Japanese military had identified the need for a true interceptor type aircraft capable of high speed, dive and climb characteristics similar to those of the A6M Reisen, but with heavier armament and longer operation at combat speeds. The aircraft was needed to intercept the Allied heavy bombers that were anticipated as the war progressed.
  • The first of three prototypes took to the air in March of 1942 and many design issues were found. Among them were problems with the retractable landing gear and the engine and prop combination. Numerous modifications were required, including changing to the Kasei 23 engine that produced 1,800 hp and included water and gas injection for emergency combat power.
  • It wasn't until December 1942 that all of the problems were believed solved and the aircraft went into production. Manufacturing was quickly halted until the causes of several crashes were determined. It was found that the tail wheel locking mechanism, when set after takeoff, caused the controls to be locked into the dive position.
  • Although only 621 Raidens of all variants were produced, the J2M3 variant remained in service until the end of the war and was responsible for downing several Allied bombers.
Reference Images
Kit Details
Even though this Buddy Build is for my 50th birthday, this kit is older than I am!
Scalemates Link
The instructions are one area that shows this kit's age. The color callouts are essentially non-existent. So I decided to use the color callouts from the more modern Zoukei-Mura kit. They have several colors called out but I found the easiest link to be using the Mission Models colors --> Vallejo Model Air.
* Not shown is the underside which will be Vallejo Pale Blue Gray [71.046].
I will most likely paint the Yellow parts instead of the decals using Vallejo Medium Yellow [71.002].
I haven't yet chosen the livery. I like the visual interest of the lightening bolts, but I am concerned about the decals. At least one of the videos I watched had these decals behaving poorly. I won't be started for a least a week longer, so I have time to decide.
Tasty subject :th:
Aotake
It appears that there is some controversy among modellers regarding the undercoating of IJN aircraft. The original instructions said "Translucent Blue."
EDIT: There is no controversy for me, I'm going with whatever I think looks cooler! :thumb2:
Reference Images
Images from History You Can Touch (blog)
I am going to experiment with Tamiya Translucent Blue over an Aluminum color. I also picked up some Vallejo Aotake [71.419]. I'll see which option I like better.
"Ordinarily it's called aodake colour but actually it is a coating from a family of transparent zabon enamels. There are two branches to it, a blue one and a green one."
"Aodake is a crystal that dissolves in alcohol and is used in coatings when assembling steel and the like. (The aodake) used for interior colours was a transparent blue colour of zabon enamel but sometimes there were green ones too. When applied in coats it becomes an ordinary dark blue colour."
http://www.aviationofjapan.com/2010/02/ ... t-one.html
Controversy already!
Didn't think that sort of thing happened in the modelling community :lol:
Oh that will do very nicely Matthew another good Tamiya :banana: :pop: :pop:
I've got my kit chosen, but I've got to get the FW190 finished first, can't do multi builds :doh:
Stokesy44 wrote: Wed Oct 08, 2025 7:20 am Controversy already!
:lol:
It does explain the colour variation rather nicely and opens it up to either colour on the plane or a combination of the 2 which is rather eye catching.
Like I said in my "edited" post. There is no controversy for me. I'll leave the debate for which color goes where to the rivet counters. I will use whatever color (or spelling) I think works best for me! :thumb2:
