Trumpeter 1/35 ISU-152K
Post your in progress builds
KungFuDrew
Post by KungFuDrew »
Hello folks! And welcome to my build of Trumpeter's 1/35 ISU-152K!
Here's a bit of history on the actual tank from Tank Encyclopaedia:
The ISU-152 was an absolute nightmare for the Wehrmacht. Much like the SU-152, it was capable of blowing Tiger, Ferdinand, and Panther turrets/casemates open. However, what made the ISU-152 inherently better than the SU-152 was its superior armor and towing power. It had three major roles – assault gun, tank destroyer and mobile artillery, which made it one of the most versatile heavy vehicles of the war. After the war, it remained in service well until the 1970s, and some even saw some unconventional action at the Chernobyl liquidation, 1986.
And a bit on its use as a tank destroyer:
Whilst not designed for this role, it inherited the name “Zveroboy” (Beast killer) from the SU-152, because it could knock out the Panther, Tiger, and King Tiger tanks, as well as the Jagdtiger, and Ferdinand/Elefant. It is actually well known for this role because the Soviets were able to make this into a very effective propaganda tool in the late war. Whilst the weight of the shells (and therefore slow loading) resulted in 1-3 rounds per minute, the sheer mechanical shock was enough to kill the crew of an enemy tank, or disable an enemy tank even without an armor penetration, which is useful because generally, these shells did not penetrate. It has even been reported that the shell could totally blow the turret off of a Tiger tank!
At Kursk, AP shells were given to the ISU-152, but these rounds were expensive, hard to make, and were in very short supply, as well as only being a little more effective than the HE round. Finally, when fired upon, the ISU-152’s 90mm, 90 degree sloped armor fared well against 75 mm German guns at long ranges, but the Tiger’s 88mm gun was always a killer. However, despite stories and amazing photos of the ISU-152’s exploits as a tank destroyer, at close ranges, it was vulnerable to German high caliber guns, and it had a low rate of fire. Not only this, but it was inaccurate, and not intended for the role. ISU-152s tended to be used for direct fire as an assault gun, which saw it fighting against enemy positions, not necessarily enemy tanks.
Here's a bit on the variant that I'll be making:
This was a modernized variant from 1956, undertaken at the Leningrad Kirov Plant and designated the Object 241K. It took a new engine, the same as the T-54 and the main, internal fuel tank now had a capacity of 920 L, giving it 500 km more operational range. It had ammo capacity for another 10 shells, now giving it a grand total of 30 shells, due to an additional fuel tank in the crew compartment being removed. The commander’s cupola and sights were reworked and improved. It was also given a new running gear design based on the T-10 heavy tank. The mantlet was given an additional armor ring – some even had 15 mm extra welded onto the 60 mm mantlet from above.
And for a bit more history on the vehicle, a couple of videos from one of Wargaming's historians Nicholas 'The Chieftain' Moran:
The Slow Mo Guys recently did a video on the Sherman tank, but also fired a Russian gun not dissimilar to the gun on the ISU-152, really helps you get an idea of the power of those Russian 152's:
I'm planning on doing a small vignette based off of this picture, shouldn't be too difficult but it's the first time I'll have done anything like this!
So, on with the kit! It looks to be a great kit, the parts are well moulded with some nice details. It comes with PE grills, copper wire for the tow cable and a chunky turned metal barrel, not bad for a kit I got on sale!
I've been working on this for a couple of days with no real problems so far, if there have been problems they've been of my own making, not the kit's fault!
Wheels mostly assembled, with some of the suspension arms:
And the lower hull mostly done:
I'll be attaching the wheels but leaving the tracks off for ease of painting.
I've got some more progress done, I just need to remember to take pictures! I'm not used to this whole documenting your progress thing! :)
That's it for now, more pics coming soon!
Thanks, Andrew
On the bench: Tamiya 1/32 F4U-1D Corsair, 1/350 USS Salem (very long term project)
Re: Trumpeter 1/35 ISU-152K
Should be a beast when it's all built up!
Loved that Slo Mo Guys video.
► Show Spoiler
Is it me, or does than cannon look ******* huge!! :eeek:
Stokesy44 wrote: Thu Mar 07, 2019 7:50 pm Is it me, or does than cannon look ******* huge!! :eeek:
It's huge, I think it was one of the biggest if not the biggest deployed operationally during WW2 :crazy:
Kevthemodeller wrote: Sat Mar 09, 2019 7:16 am
My thoughts exactly! Another beast I didn't know anything about... I need to go and read up on Soviet tank destroyers.
Tomcat64 wrote: Sat Mar 09, 2019 8:32 am
Wasn't that accurate, but 152mm shell will still rattle ya gums with a near miss. Wasn't called a '' Beast Killer for nothing ".
I was considering building the Bronco version before I settled on my finial choice.
Be interesting to see how the trumpy version builds.
:th: :cheers2:
definitely a big girl, I'm looking forward to seeing it come together, these big Russian beasts were things I didnt know a lot about either!
KungFuDrew
digger303 wrote: Sat Mar 09, 2019 10:24 am
:th: :cheers2:
It is indeed a beast! This is what it did to a Panther!
You definitely wouldn't want to be on the wrong end of that gun when it went off!
I've been cracking on with the kit, the upper hull is attached and I've got that monster of a cannon on:
I've also got one side of the tracks completed:
All the road wheels are glued on but the idler and drive wheels are just press fitted so I can remove the tracks when it come time for painting.
The postie delivered my figures the other day, I've built a couple of them up:
The detail is good on them but they need a bit of clean up and some filler, so no major problems.
That's where I am now, I'll be turning my attention to the base of the dio/vignette soon, any comments, critique and criticism welcome!
Thanks, Andrew
BOOM!! That panther didn't stand a chance!
The kit looks great, and the cannon somehow looks even bigger now it's been attached!
Nice work - that's come together really well. :cheers2:
And yeah that's a helluva mess of a Panther!
Nice subject
They really look scary when they charge at you
I made 1 years ago but i still have 1 in the stash
That is a prototype though (one many WOT players should know) as it was armed with the 152mm BL-10 gun to increase the range
Good luck with the remainder of the build
It's going together very nicely mate :th:
Tracks look great and that gun just aint getting any smaller!
Scary shot of that destroyed Panther too
Hi KungFuDrew - just a reminder that we only have a month to go in this SIG - hope you can get your build done in time :)
