Albatros D.V
Albatros D.V
Here's my entry, this time built pretty much out of the box so limited PE but I will be rigging :th: Only my second aircraft since returning to the hobby and my first WW1 for well over 30 odd years :crazy:
(From Wiki)
Design and development
Captured Albatros D.V (serial D.1162/17) with British roundels.
Manfred von Richthofen's Albatros D.V (serial unknown).
In April 1917, Albatros received an order from the Idflieg (Inspektion der Fliegertruppen) for an improved version of the D.III. The resulting D.V prototype flew later that month. The D.V closely resembled the D.III and used the same 127 kW (170 hp) Mercedes D.IIIa engine. The most notable difference was a new, fully elliptical cross-section fuselage which was 32 kg (71 lb) lighter than the partially flat-sided fuselage of the earlier D.I through D.III designs.[1] The new elliptical cross-section required an additional longeron on each side of the fuselage and the fin, rudder and tailplane initially remained unchanged from the D.III.[1] The prototype D.V retained the standard rudder of the Johannisthal-built D.III but production examples used the enlarged rudder featured on D.IIIs built by Ostdeutsche Albatros Werke (OAW).[2] The D.V also featured a larger spinner and ventral fin.
Compared to the D.III, the upper wing of the D.V was 121 mm (4.75 in) closer to the fuselage, while the lower wings attached to the fuselage without a fairing. The D.V wings were almost identical to those of the standard D.III, which had adopted a sesquiplane wing arrangement broadly similar to the French Nieuport 11. The only significant difference between wings of the D.III and D.V was a revised routing of the aileron cables that placed them entirely within the upper wing.[3] Idflieg conducted structural tests on the fuselage but not the wings of the D.V.[4]
Early examples of the D.V featured a large headrest, which was usually removed in service because it interfered with the pilot's field of view.[3] The headrest was deleted from the second production batch.[5] Aircraft deployed in Palestine used two wing radiators, to cope with the warmer climate.
Idflieg issued production contracts for 200 D.V aircraft in April 1917, followed by additional orders of 400 in May and 300 in July.[4] Initial production of the D.V was exclusively undertaken by the Johannisthal factory, while the Schneidemühl factory produced the D.III through the remainder of 1917.
Operational history
Albatros D.Va (serial D.7098/17)
The D.V entered service in May 1917 and structural failures of the lower wing immediately occurred.[4] In 2009, Guttman wrote that "Within the month Idflieg was doing belated stress testing and concluding, to its dismay, that the D V’s sesquiplane wing layout was even more vulnerable than that of its predecessor".[6] The outboard sections of the D.V upper wing also suffered failures, requiring additional wire bracing, and the fuselage sometimes cracked during rough landings.[6]
Against these problems, the D.V offered very little improvement in performance.[3][4] Front line pilots were considerably dismayed and many preferred the older D.III; Manfred von Richthofen was particularly critical of the new aircraft. In a July 1917 letter, he described the D.V as "so obsolete and so ridiculously inferior to the English that one can't do anything with this aircraft". British tests of a captured D.V revealed that the aircraft was slow to manoeuvre, heavy on the controls and tiring to fly.[7]
Albatros D.Va (serial D.5629/17)
Albatros responded with the D.Va, which featured stronger wing spars, heavier wing ribs and a reinforced fuselage.[8] The modified D.Va was 23 kg (51 lb) heavier than the D.III but the structural problems were not entirely cured. Use of the high-compression 130 kW (180 hp) Mercedes D.IIIaü engine offset the increased weight of the D.Va.[9] The D.Va also reverted to the D.III aileron cable linkage, running outwards through the lower wing, then upwards to the ailerons to provide a more positive control response. The wings of the D.III and D.Va were interchangeable.[3] To further strengthen the wing, the D.Va added a small diagonal brace connecting the forward interplane strut to the leading edge of the lower wing; the brace was also retrofitted to some D.Vs.[9]
Idflieg placed orders for 262 D.Va aircraft in August 1917, followed by orders for another 250 in September and 550 in October. Ostdeutsche Albatros Werke, which had been engaged in production of the D.III, received orders for 600 D.Va aircraft in October. Deliveries of the D.Va commenced in October 1917.[8] The structural problems of the Fokker Dr.I and the mediocre performance of the Pfalz D.III left the Luftstreitkräfte with no alternative to the D.Va until the Fokker D.VII entered service in mid-1918. Production of the D.Va ceased in April 1918.[10] In May 1918, 131 D.V and 928 D.Va aircraft were in service on the Western Front; the numbers declined as the Fokker D.VII and other types replaced the Albatros in the final months of the war. By 31 August, fewer than 400 Albatros fighters of all types remained at the front but they continued in service until the Armistice.[11]
Specifications (D.V)
Official Albatros D.V Baubeschreibung drawing, submitted to IdFlieg
Data from German Aircraft of the First World War[15]
General characteristics
Crew: 1
Length: 7.33 m (24 ft 1 in)
Wingspan: 9.05 m (29 ft 8 in)
Height: 2.7 m (8 ft 10 in)
Wing area: 21.2 m2 (228 sq ft)
Empty weight: 687 kg (1,515 lb)
Gross weight: 937 kg (2,066 lb)
Powerplant: 1 × Mercedes D.IIIaü piston engine, 150 kW (200 hp)
Propellers: 2-bladed wooden propeller
Performance
Maximum speed: 186 km/h (116 mph; 100 kn)
Endurance: 350 km
Service ceiling: 5,700 m (18,700 ft)
Rate of climb: 4.17 m/s (821 ft/min)
Time to altitude: 1,000 m (3,281 ft) in 4 minutes
Armament
Guns: 2 × 7.92 mm (0.312 in) LMG 08/15 machine guns
References
Notes
Mikesh 1980, p. 15.
Grosz 2003, pp. 21–22.
Connors 1981, p. 22.
Van Wyngarden 2007, p. 40.
Guttman 2009, p. 31.
Guttman 2009, p. 22.
Bennett 2006, p. 124.
Van Wyngarden 2007, p. 65.
Mikesh 1980, p. 17.
Mikesh 1980, p. 7.
Herris 2001, p. 154.
"Albatros D.Va Scout Aircraft." Australian War Memorial. Retrieved: 20 July 2017.
"Conservation of the Albatros D.Va." Australian War Memorial. Retrieved: 21 July 2017.
"Albatros D.Va - Old Rhinebeck Aerodrome". oldrhinebeck.org. Old Rhinebeck Aerodrome. 2014. Archived from the original on November 10, 2014. Retrieved August 9, 2017. In 2013 the Albatros entered the shop for restoration, where the decision was made to change the livery for the first time. The aircraft was repainted in the brilliant colors of the D.V / D.Va flown by Lt. Hans Böhning of Jagdstaffel 36 / Jagdstaffel 76 and returned to the air in May 2014
Gray and Thetford 1970, p. 52.
Re: Albatros D.V
Awesome Kev, cool looking old bird :thumb2:
Interested to see how you get on with this, have a couple WWI Eduardo’s in the stash
Good luck mate
Re: Albatros D.V
Nice kit and looks like a fun build. :th: :th: :th:
Re: Albatros D.V
Looking forward to this mate :thumb2:
Re: Albatros D.V
Nev wrote: Wed Sep 19, 2018 11:35 pm Looking forward to this mate :thumb2:
pourquoi61 wrote: Wed Sep 19, 2018 10:47 pm Nice kit and looks like a fun build. :th: :th: :th:
I'm so looking forward to starting this build, got a real soft spot for WW1 aircraft and my stash WNW is every growing :th:
This and perhaps a couple more Eduard kits will be my experience gaining kit/s to hone my skills for WW1 aircraft building :th: :dance:
Just got to finish the B17 which is moving on nicely now so a week or so and this build will start. :th: :th:
Re: Albatros D.V
This is one cool plane, definitely getting the popcorn for this one! :pop:
Re: Albatros D.V
Damn, I think I may be slipping. This needs to be posted...”what flavour is it???”
Re: Albatros D.V
Quax wrote: Sun Sep 23, 2018 8:39 pm This is one cool plane, definitely getting the popcorn for this one! :pop:
Thanks mate
Re: Albatros D.V
Twokidsnosleep wrote: Sun Sep 23, 2018 9:26 pm Damn, I think I may be slipping. This needs to be posted...”what flavour is it???”
:lol: :lol: :lol: :lol:
Re: Albatros D.V
The build has started :banana: :banana: :th: work has been all enveloping of late :( but I got some time on Fri /Sat and hopefully today :th:
I started with the engine which isn't following the instructions but suits me better. The cylinder block was bowed out slightly and there was no locating pins so lining it up was tricky
First stage parts all cleaned up and ready for priming/painting and detailing :th:
Timplastic
UN
Re: Albatros D.V
Post by Timplastic »
That’s a great looking kit.
Really like the albatross, got it in the wnw boxing. Lots of wood and lozenge for those planes.
What sceme you doing. Box art or the dragon ?
I believe the dragon is bare wood, hope you do that
Watching along happy to see how it goes :pop:
I like to know what you think even if it is critique , If you spotted it let me know
Trying to finish what I started, and take part
My youtube channel that needs some updates
https://www.youtube.com/channel/UCjQvLz ... subscriberImage
Re: Albatros D.V
Timplastic wrote: Sun Oct 14, 2018 11:37 am That’s a great looking kit.
Thanks mate, I'm going for this version https://www.eduard.com/store/out/media/ ... 8113_4.jpg
I'm using this build and may be another depending how this one goes as practice before I start my WNW builds and like you I've got a DV in my WNW stash. :th:
Timplastic
UN
Re: Albatros D.V
That’s a great pick. Always scared of doing an all black paint. With the wings and big flower that’s going to be a great one in the display. Going to have a look for a 1/48 dv now
Re: Albatros D.V
Eduard fit isn't as good as I was expecting, the points above about fit and I had to make up a packing piece for the magnetos and cam drive unit, all worked out fine in the end.
The bridges on the struts could be better took a lot of time sorting these out :crazy:
Before on the left after on the right
Starting to paint :th:
Re: Albatros D.V
Looking good and nice work dealing with the fitment. I have a couple Eduards to make but have never built one
When you do the WNW you will be raving at how everything goes together..it just does
Though it is definitely on the tight side of alignment usually with good fitting pins
Timplastic
UN
Re: Albatros D.V
What it doesn’t fit together ? And I just got mine in the post. Ow no ! Lol
When I looked on scalemates it’s actually quite an old kit and I did like the little pilot
Good job on the work so far
Re: Albatros D.V
Twokidsnosleep wrote: Tue Oct 16, 2018 4:06 pm Looking good and nice work dealing with the fitment. I have a couple Eduards to make but have never built one
It's not anything like Revell but I was expecting almost Tamiya level from Eduard that's the impression I got from reading and reviews :scratch:: little disappointed if I'm honest.
I think there's going to be a few dramas with the wing struts, the holes and the struts don't all line up and the clearance is too big on some. In other words you can't push the struts in and they stay there, they will either just fall over/out or not go in without a bit of flexing, aligning them with the wings is going to be interesting. I think one of those jigs will be needed and it's going to be very, very tricky not damaging the lozenge :crazy:
Last edited by Kevthemodeller on Tue Oct 16, 2018 7:42 pm, edited 1 time in total.
JoaquinGM
Spain
Re: Albatros D.V
Post by JoaquinGM »
I love biplanes.
I am going to stay here and see.
:pop: :pop:
Re: Albatros D.V
Got some bench time yesterday evening, had a go at some wood effect didn't come out too bad :th: I think it's a little too dark.
Tat2bhoy
Re: Albatros D.V
Post by Tat2bhoy »
Kevthemodeller wrote: Thu Oct 18, 2018 7:48 pm Got some bench time yesterday evening, had a go at some wood effect didn't come out too bad :th: I think it's a little too dark.
The wood looks great as it is, nicely done :th:
Image Image #32
Revell 1:72 Type IXC/40 U-Boat ✅
Meng 1:48 Messerschmitt Me410 B-2/U2/R4 Heavy Fighter✅
Miniart 1:35 T-54-2 Soviet tank✅
Re: Albatros D.V
doing great...the wood effects look very effective. :cheers2:
Re: Albatros D.V
digger303 wrote: Fri Oct 19, 2018 3:04 pm
Thanks digger it's not too bad in this scale you shouldn't really see too much grain effect that's what I was aiming for, just think it's a little too dark.
Re: Albatros D.V
Got some bench time over the weekend. Started to fit out the cockpit, the moulding on most smaller parts is poor. If you enlarge you can see the on the T handles where the moulds haven't been aligned correctly, this is really annoying and time consuming, on the parts I've had to correct like the wing struts.
Also things like the rudder peddle frame where it supposed to join the bulkhead, the holes are way too small, pins way too big and suffer the same as the T handles. You've got to check, modify and dry fit every part, I'm really disappointed at this aspect, I was expecting more from Eduard.
Hopefully I'll have the engine sealed and ready for weathering later today.
Re: Albatros D.V
Engine and wood look superb :thumb2:
A bit Surprised with the mouldings...with the WNW stuff is made to look pretty spot on I must say
You will blow one away seeing what you are able to do with this Eduard
Re: Albatros D.V
Twokidsnosleep wrote: Mon Oct 22, 2018 5:16 pm Engine and wood look superb :thumb2:
Thanks mate, I am very much looking forward to the WNW kits :th:
Re: Albatros D.V
Here's another example of poor fit/moulding :pistols:
The gray bracket in the middle is the rear mounting for the machine guns, it fit into the oblong with a dimple you can see on each side of the fuselage. Take a look at the ends of the bracket and the depth of the dimple. It's not deep enough to dry fit and stay there, if I deepen it and then try it could well be too deep and it wont reach the other side, equally it could be too long and need trimming but by how much? Somehow I've got to try and fit it while the two half's of the fuselage are dry fitted and slightly apart. or mess about with PVA glue :wtf: :bash:
To my mind if parts need to be fitted into one side and then the other side brought to it, there must be provision for the parts to locate securely into one side, this can't be done on this kit :bash: :wtf:
I'll end up damaging the finished surfaces trying to fit it, as you can see I've already damaged the paint where the engine tacho is mounted :bash: and this is where all the time goes not good Eduard not good :pistols:
Re: Albatros D.V
Yet more :pistols: :pistols: :pistols: :pistols:
Here's the control stick take a look at the locating nipple :pistols:
It fits in here
The end of the rod with the disc is where the control cables would be secured to is supposed to fit in this hole or rather dimple
Firstly the rod isn't long enough, second the holes are out of line the forward one being too low
You can also see all the damage to the painted surfaces :pistols:
Now when you consider this kit cost just over £20 and a Tamiya 1/48 aircraft is either cheaper or only £5 more for an average kit the difference in quality is significant. Admittedly Tamiya don't do WW1 (I wonder why?) Eduard in my opinion you need to do better I'm not sure I'll buy another!
That's enough moaning :crazy: :th: :th:
Re: Albatros D.V
I have two Eduard WWI kits in my stash; a Camel and a Nieuport :think:
You are making me think of putting them up on eBay for sale :scratch::
I was going to practice on those before a WNW, I think that may be fuzzy logic, beating yourself up when better kits are available
I am feeling like that for a lot of stuff in my stash
Re: Albatros D.V
Twokidsnosleep wrote: Mon Oct 22, 2018 8:16 pm I have two Eduard WWI kits in my stash; a Camel and a Nieuport :think:
That's what I'm doing, practicing with Eduard before I move on to my WNW kits. I think it's a bit late for you mate you've already started a WNW haven't you. :dance:
I'd check your Eduard kits out first, I think if you know what you're up against its not so bad. I was not expecting and I'm surprise at the extent of what I've got. Based on reviews Eduard WW1 aircraft are pretty much second in line to WNW, then Roden who get some very hit and miss reviews.
I'm sure it will turn out ok but I must confess I'm not relishing the wing struts :wall: :doh:
Re: Albatros D.V
Kevthemodeller wrote: Mon Oct 22, 2018 11:10 pm
I just looked up scalemates and it appears your kit originally hails back to 1995. Possibly why the kit is a little under done. I don't know if this came from another manufacturer or not.
Re: Albatros D.V
digger303 wrote: Tue Oct 23, 2018 12:16 am I just looked up scalemates and it appears your kit originally hails back to 1995. Possibly why the kit is a little under done. I don't know if this came from another manufacturer or not.
I did the very same Digger, and looked up kit reviews and builds they never mentioned these issues. It's very possible I've been spoilt with reading and following many WNW and Tamiya builds that my expectations are just too high. It just means I've got to dry fit every part every part, which isn't always easy or possible, the way this kits engineered doesn't help either eg no or very poor location points.
As I said the wing struts are going to a nightmare as the struts pins are very small and the location hole in the wings are too big :wtf: :crazy:
I'll get it sorted somehow and it's all good experience, but this I believe should be reflected in the price of the kit :pistols:
Re: Albatros D.V
Kevthemodeller wrote: Tue Oct 23, 2018 8:34 am
Very true...paying good money for yesterdays tech
Re: Albatros D.V
Superb work on the wood effects Kev and such a shame that old-fashioned engineering is letting the kit down, it's frustrating as hell.
Hope you keep at it and kick it into shape mate :th:
Re: Albatros D.V
Yes it is the sort of thing that you might expect from a 1970's kit, looking great despite the kit's weaknesses. :th: :th: :th:
Panzergrau
Sint Maarten
Re: Albatros D.V
Post by Panzergrau »
Hi, Kev! I'm catching up with your build now. Well done despite the kit's molding issues. I think it's safe to say that Eduard are still tributaries to their Eastern-European origins and the plastic isn't always the best. What makes Eduard great is the great rapport between the number of parts and the level of detail and, of course, their additions in pre-painted PE.
I hope I can follow your thread constantly from now on, since I'm building a WWI aircraft as well and there is an interesting similitude, although my aircraft is a different one. I also have a few 1/48s from Eduard in my stash and... I was hoping for better.
You've done excellent so far; keep it up!
Cheers!
Gabriel :thumb2:
Re: Albatros D.V
Panzergrau wrote: Wed Oct 24, 2018 1:40 am Hi, Kev! I'm catching up with your build now. Well done despite the kit's molding issues. I think it's safe to say that Eduard are still tributaries to their Eastern-European origins and the plastic isn't always the best. What makes Eduard great is the great rapport between the number of parts and the level of detail and, of course, their additions in pre-painted PE.
Cheers!
Gabriel :thumb2:
Hi Gabriel,
Thank you for your very kind comments :th: Don't get me wrong I'm not saying the kit is no good, or Eduard far from it, just I'm a little disappointed with it's quality given what I've read about this kit and other Eduard WW1 aircraft kits in general, which is all good. Now I know every part no matter how big/small must be dry fitted first a lot of the frustration of having to modify simple parts after they've been painted should disappear :th: And I've adjusted my expectations of their moulding quality of smaller parts.
Eduard do make some very interesting WW1 aircraft as do Roden, it's just a shame they can't achieve WNW level quality even if it cost a little more and why don't Tamiya market WW1 aircraft?
Panzergrau
Sint Maarten
Re: Albatros D.V
Hi, @Kevthemodeller, I'm not that "scared" of Eduard. I have my own (limited) experience with them and as you said: if you manage to deal with their small mold and fitting issues, you're golden! I built the MiG-15 from them and I have to admit that it is still the best kit out there and once completed it looks fantastic. I'm just a little annoyed - as you are - that a company with such prestige and obvious capabilities doesn't apply a slightly tighter QC.
Cheers!
Gabriel :thumb2:
Re: Albatros D.V
Finally got a round to some bench time, work is just crippling at the moment :wall: and time to post what i've been doing over the last week or so :th:
Little bit of modding to the exhaust
The almost finished engine
More moulding issues this time the leading edge of the upper wing
After some work
Almost close up :th:
JoaquinGM
Spain
Re: Albatros D.V
Post by JoaquinGM »
Kevthemodeller wrote: Wed Oct 31, 2018 8:20 pm
I like these exhaust pipes. Take care of varnishing glossy. Destroy that beautiful effect.
Re: Albatros D.V
I like what you have done with the engine :th: :th: :cheers2:
Re: Albatros D.V
The D.V bar is set very high! It will be a challenging task to compete against this level of work.
Re: Albatros D.V
JoaquinGM wrote: Wed Oct 31, 2018 9:59 pm I like these exhaust pipes. Take care of varnishing glossy. Destroy that beautiful effect.
Thank you, they're sealed already :th:
Re: Albatros D.V
digger303 wrote: Wed Oct 31, 2018 11:39 pm I like what you have done with the engine :th: :th: :cheers2:
Thanks Digger :th: I was going to bling it right up, spark plug leads etc but like the rest of the build I'm deliberately not adding PE etc, I'm saving all that for my WNW :banana:
Re: Albatros D.V
bfrd wrote: Thu Nov 01, 2018 12:12 am The D.V bar is set very high! It will be a challenging task to compete against this level of work.
That's a very kind comment mate, thank you :th: I'm really looking forward to your DV, and I'm sure it will be a cracker :th:
As I said earlier, I've just added that kit to my stash, got a real keen interest in WW1 Aircraft at present :cheers2:
Re: Albatros D.V
Nice. :th: :th:
Re: Albatros D.V
pourquoi61 wrote: Sat Nov 03, 2018 9:22 pm Nice. :th: :th:
Thanks mate :th:
Re: Albatros D.V
I've been slowly chipping away at it :th: Work is really crippling at present long hours and work load :pistols: :wall:
I've also reach almost 1200 hundred on the Flicker so I'm going to get capped, I really don't want to post any more only to have to delete them or worse lose them as I've done with the bucket mob :pistols: :pistols: :pistols:
So it means no more pictures until I can sort things out :pistols: :pistols:
Re: Albatros D.V
Beautiful work on the engine Kev - that's stunning :banana:
Re: Albatros D.V
Tomcat64 wrote: Mon Nov 05, 2018 11:35 am Beautiful work on the engine Kev - that's stunning :banana:
Thanks mate :th:
I did have a fairly good few hours yesterday, albeit I hit a few of the fitment issues I mentioned earlier, this time it was trying to fit the PE seat belts what a pain :wall: They're are not only too long (scale issues there I think) but very difficult to bent and shape into/around the seat, because there's no locating point to mount the seat bulkheads they broke away and the whole unit fell out of the fuselage :bash:
I got it sorted but bloody annoying :wtf:
Re: Albatros D.V
I've had a really busy last couple of weeks, work and away on the WW1 battlefields which for me is a annual event. :th:
Last few days work :th:
Wings painted and ready for the lozenge decals :th:
More kit issues, as you can see the hole in the engine for the prop is out of line with the fuselage :wtf: It's not an issue as the prop pin don't really need to enter the engine but just another example of the kit quality :pistols:
Even the PE isn't issue free the printed areas are out of register and/or too big, not a good picture but the print is hanging off the dial :pistols:
The seat belts are in, the fuselage is ready to be closed up :banana:
Closed :th:
Return to “Build Threads”
