1/48 Esci S-3A Viking
Post your in progress build threads here with regular updates
I must be mad as I will have two builds going at the same time. :crazy: :crazy: :crazy:
This kit is 36 years old! You can tell by the decals and muck/mold on the kit.
It was a bargin when I bought it, or was it?
BENT WINGS ON THE TOP AND BOTTOM. :eeek: :eeek: :eeek:
GOT SOME NEW DECALS.
NICE.
Going to have some fun with this one.
Thanks for dropping by. :th: :th: :th:
Got to go mow the lawn now. :( :( :(
Re: 1/48 Esci S-3A Viking
Interesting entry :think:
I read the blurb, she has bomb bay doors and a bomb hold so it qualifies :th:
Welcome to the sig and I wish you luck for your build
Good start with your excellent photography :clap:
:cheers2: Scott
Oh, when you are done with the lawn, come mow mine....oh nope, I forgot it is plastic turf and no mowing needed :banana: :banana: :banana:
Twokidsnosleep wrote: Sat May 05, 2018 2:44 pm Interesting entry :think:
:cheers2: Scott
Thanks very much and I hope your turf doesn't melt.
pourquoi61 wrote: Sat May 05, 2018 2:56 pm
:cheers2: Scott
Hopefully it will improve my short game.
smokeriderdon
Post by smokeriderdon »
Got your work cut out for ya here. But nice decal sheet you picked up there! I think I would be doing the black tail myself. Though I would NOT call that low vis! LOL
This looks like a boat with wings tacked on :dance: :cheers2:
The mighty Hoover! Looks like a fun build!
smokeriderdon wrote: Sat May 05, 2018 3:27 pm Got your work cut out for ya here. But nice decal sheet you picked up there! I think I would be doing the black tail myself. Though I would NOT call that low vis! LOL
And don't I know it.!
Yes low viz my A*&^%$$$££^%&**. :lol: :lol:
digger303 wrote: Sun May 06, 2018 1:54 am This looks like a boat with wings tacked on :dance: :cheers2:
A boat with holes mate! :lol: :lol:
aur0ra145 wrote: Sun May 06, 2018 3:31 am The mighty Hoover! Looks like a fun build!
Hoover? :scratch:: :scratch:: :scratch::
I thought that I would start with fixing the front wheel well in first, as the fuselage looks a bit twisted.
It might help with the gluing together later on.
The next shot is with just the bomb bay and landing gear housing lined up and held in place.
:scratch:: :scratch:: :scratch:: :scratch:: :scratch::
So looking at the instructions the "office" goes in once the fuselage is together.
So I was thinking that if I install the tub to one side it might help with the alignment issues?
Looking at the decal sheet for the instrument decals I thought that I would have a go myself to improve it? :lol: :lol: :lol: :lol:
I found some plastic card and started cutting up small pieces.
Stuck a few on.
Once dry the overlap on the side panels.
Was sanded off.
Looks a bit naff.
So I put some smaller squares on and added a throttle made from an engine mount from my spares box.
I then built the two seats and sprayed Tamiya XF-22 RLM Grey.
For some strange reason I wanted to build a fire extinguisher.
So I found this,Part 16 from the same sprue as the throttle lever.
Sprayed that RLM Grey.
I added small blobs of colour using the end of a cocktail stick to represent switches.
Also a resistor and a small piece of wire.
Oh while waiting for paint and glue to dry I started cleaning up the MAD BOOM?
I filled the holes with my home made filler/glue.
Once dry sanding down.
That's all for today folks.
Super :thumb2:
Cockpit looks great
Twokidsnosleep wrote: Wed May 09, 2018 9:05 pm Super :thumb2:
Cockpit looks great
Cheers, I know it is out of scale but it is ok.
pourquoi61 wrote: Wed May 09, 2018 8:08 pm
It's what the Navy aircrew called them. If you've ever heard one, they sound like a Hoover vacuum. Sort of like how we call the E-2 Hawkeye a "Hummer" because of the sound the props make.
Super job on the office mate, you've really brought a nondescript selection of kit plastic to life :th: :th:
Fantastic work on detailing up the cockpit mate - that's really eye-popping!
As for the fit on the other parts... :scratch::
Nice choice mate
gaz45 wrote: Fri May 11, 2018 11:38 am Nice choice mate
Thank you sir, I only hope I will do a good job on this hoover.
aur0ra145 wrote: Wed May 09, 2018 11:51 pm
I shall have to check out you tube for a video. :thumb1:
On with the build and I brush painted Tamiya XF-22 RLM Grey.
The instructions tell you to weight the nose of the aircraft, but not how much, so I got out the wheel weights.
As you can see I have put 50 grams in the plane.
With no detail on the cockpit dash I cut up small pieces of plastic card, a few of which I drilled to represent screens.
With a splash of colour it looked better.
I used the decals for the overhead console.
Dash added to the office.
With the paint drying I built the MAD Boom.
With the cockpit and boom in place I started to assemble the plane.
I started by gluing the lower part of the fuselage and then clamping.
You can see the misalignment in the next few photos.
I moved first to the cockpit to glue and fill with card.
So that is all for today.
Awesome!!
I always forget to do the nose weight before I seal the fuselage, so thanks for the reminder...I am a long way off still unfortunately
Keep up your great detailed work :thumb2:
Door prize draw coming up this weekend :banana:
:jd: wow, you’re doing some great work with this kit, hope the rest goes ok for you. This is one plane I’d love to build, but there don’t seem to be many out there.
Nice looking aircraft and your doing a bang up job painting it. :th: :cheers2:
chief5437 wrote: Tue May 15, 2018 10:38 pm :jd: wow, you’re doing some great work with this kit, hope the rest goes ok for you. This is one plane I’d love to build, but there don’t seem to be many out there.
Thanks so far so good, but I have hit a problem as you might see in the next build up date.
Bent wings and I need some help.
Ideas welcome.
:th: :th:
digger303 wrote: Wed May 16, 2018 4:51 am Nice looking aircraft and your doing a bang up job painting it. :th: :cheers2:
Thank you sir but I now need some help.
check out my new post. :eeek: :eeek:
Okay today I have been busy, two builds going on and I am getting on with the Viking.
Fuselage glued together.
So we have an intake in the tail section that needs improving so I insert some 4.8mm hollow rod in to the hole.
I had to sand the tube to get a nice fit.
Cut the extra off with a fine saw.
I filled the hole visible in one of the earlier pictures with plastic card and glued on the sonobouy dispenser(s).
Here I need to ask you all for some advice, as I so far have been unable to straighten out the wings in this kit, while I do have another kit I can steal the wings from, I'd like that to be a last resort. With that in mind, do any of you have some suggestions as to how I can fix the following?:
I appreciate any and all advice you can give.
Fridgy
Post by Fridgy »
Could you warm them up in hot water and then get them straight?
I have no idea if it would work though
Mick
WIP: 1/12 Bandai BB-8 & R2-D2
a large enough tub for the wing to fit in. Fill with warm to hot water ...not boiling. something flat as long as the wing to press down on the whole wing so it straightens and it doesn't bend in the wrong place. spacers may be needed to place under the ends. These shouldn't be too high just enough to bend past the point you want it as it may have some spring in it and that will compensate for that. do it without them first and see how it goes. Careful you don't put a flat spot into the plastic.
Don't use a hairdryer as you can over heat an area then the plastic will collapse.
Fridgy wrote: Wed May 16, 2018 11:53 pm Could you warm them up in hot water and then get them straight?
Thanks for that mate. :th:
digger303 wrote: Thu May 17, 2018 12:26 am a large enough tub for the wing to fit in. Fill with warm to hot water ...not boiling. something flat as long as the wing to press down on the whole wing so it straightens and it doesn't bend in the wrong place. spacers may be needed to place under the ends. These shouldn't be too high just enough to bend past the point you want it as it may have some spring in it and that will compensate for that. do it without them first and see how it goes. Careful you don't put a flat spot into the plastic.
Okay thanks for the tip, have you had the same problem at any time? :th: :th:
I had this with the s-2 tracker I’m building, but it was the fuselage. I taped the parts together to see it they would straighten out once assembled. They did, so I started by glueing from one end. Just a bit at a time, letting it dry before moving on to the next bit. Adjusting as necessary to maintain the shape. Worked great for me.
I’ve only tried the hot water thing on resin, not sure it works on styrene?
chief5437 wrote: Thu May 17, 2018 11:15 am I had this with the s-2 tracker I’m building, but it was the fuselage. I taped the parts together to see it they would straighten out once assembled. They did, so I started by glueing from one end. Just a bit at a time, letting it dry before moving on to the next bit. Adjusting as necessary to maintain the shape. Worked great for me.
Okay thanks for that one,I did that with the fuselage but it was not as warped as the wings.
Cheers. :th: :th: :th:
Skullfish
Post by Skullfish »
Brilliant job on the office and admire your scratch building/detailing.
Good luck with the rest of the build. Interested to see the outcome of the wing wrangling.
Jase.
On the bench.
keep increasing the water temp if it doesn't work the first time a bit at a time.
Skullfish wrote: Fri May 18, 2018 3:16 am Brilliant job on the office and admire your scratch building/detailing.
Jase.
Thank you, got some ideas from other members and going to give them a try. :th: :th:
digger303 wrote: Fri May 18, 2018 3:56 am
Will give it a go. :th: :th:
On with the build, but firstly I would like to say a big thank you to Chief 5437, Digger 303 and Fridgy for ideas on how to straighten the wings on this build. :cheers2: :cheers2: :cheers2: :cheers2:
So this is what we are talking about.
First I glue the wingtip and clamp.
I then re-clamp it to a straight piece of wood.
The wing was left till the next day before I glued the next part.
The wing was left again for a day.
The rear part of the wing was then glued, clamped and left to dry.
I also clamped the lower section of the other wing to see if that might help.
The next day I removed the part-glued wing from the wooden strip, to find out that the pin and hole was misaligned and once lined up it gave a big step at the front of the wing.
Sorry for poor photo.
I then removed the pin with a sharp knife and did my best to get a pleasing/passable result.
The fixing tabs had to have 3mm removed off each end before they would fit into the slots provided.
Not brilliant but ok.
One more to do now.
:cry: :cry: :cry:
Johno
Post by Johno »
Nice save there, well done!
Moebius 1/32 viper mk. vii
Hasegawa 1/72 vf-1A/S/J
Airfix 1/32 WW1 B type 'Ole Bill' bus
:boom:
Fridgy
Post by Fridgy »
That worked well mate. Nice save
Mick
Great work on sorting those wings out :clap:
Good to see you found a way to sort those wings out, much better now.
Fantastic work so far and great save with that wing. Looks nice and straight now! :th: :cheers2:
Johno wrote: Sun May 20, 2018 7:11 pm Nice save there, well done!
I am only half done, the second wig is worse.
Thanks for the comment. :th: :th: :th:
alextheblue wrote: Mon May 21, 2018 3:34 pm Fantastic work so far and great save with that wing. Looks nice and straight now! :th: :cheers2:
That was part one.
The second wing is worse. :eeek: :eeek: :eeek:
Thank you any way. :th: :th: :th:
Fridgy wrote: Sun May 20, 2018 11:52 pm That worked well mate. Nice save
The second wing is worse. :jd:
It could be a nasty part two, but thanks for your comments. :th: :th: :th:
Nice recovery! Great idea clamping it to the wood. Fingers crossed, the other wing will turn out just as good!
chief5437 wrote: Tue May 22, 2018 2:31 pm Nice recovery! Great idea clamping it to the wood. Fingers crossed, the other wing will turn out just as good!
Thanks we will see. :th:
The second wing has to be put straight now.
I will start like last time by gluing the wingtips and fixing it to my trusty slither of wood, leaving to dry and then adjusting and gluing as I go.
Just a reminder.
Wingtips first.
But this time a little more clamping needed to be done.
I had high spots and low spots on this wing, so I had to raise the low spots.
So when the wingtip was dry I cut out some plastic card to lift the low area. The wing was forced open and a square of 2mm plastic card was pushed into place with the tip of a modelling knife and the edges pressed together. This seemed to lift the low area so I pushed in the needle applicator of the glue and fixed it in place.
Clamps were added to the wing edges once glue was applied.
After an hour or so the clamps came off, it looked passable. :think: :think:
Looking at the wing root I could see that same process would be used to lift low areas and push down on high areas on to plastic under neath
More oblongs of plastic would be needed, they were eyeballed and cut and pushed into place.
The result is okay but not fantastic. Glue was applied and she was clamped down.
I did not take pictures when cutting and gluing as I was too involved in trying to make a reasonable job of it.
You can see the plastic shapes as I hold the wing up to the light.
If I come across this again I will cut the plastic to fit the inside of the wing and build up and sand down first.
The horizontal stabilisers had to be clamped to the magic wood, glued and clamped.
I can see why the kit only cost £8:25 in the sale. :bash: :bash: :bash:
And on the other end.
After drying time the second wing and stabilisers were test fitted, sanded and refitted.
Once happy I fixed them in to place.
Not brilliant but part of the learning curve.
I will see what I can do to tweek the wings, or it will be some highlights and lowlights to give an illusion of a straight flat wing.
:lol: :lol: :lol: :lol: :lol:
NB. One of the undercarriage legs is broken so I have sent for some metal ones to replace and give strength to hold the weight.
You are doing great straightening up those wings :thumb2: :clap:
Most people would have given up and binned the thing
