#12 Quax ICM 1/48 Junkers JU88 A-4 Torp
Post your in progress build threads here with regular updates
so here we go after all this waiting!
Here are the sprue shots to start with, its going to be out of the box but I may well invest in a masking set as one thing I did learn from the 1/72 version is there's one heck of a lot of glass!
The various paint options but very annoying that it doesn't give you a top view for the squiggle pattern.... :wall: :scratch::
fewer decals by far on this 1/48th compared to Revels 1/72nd. This is a good thing :nena: :banana:
[url=https://flic.kr/p/H3vvpk]Image
bit of the cockpit detail
A nice looking kit but we'll see how it goes together. Life is going to be busy as I'm entering a tank in the Cold War GB so we might end up with a JU88 with a 120mm gun or a Chieftain with wings..
Good luck everybody and many thanks to TKNS for driving this through :bow:: :bow::
Les0012
Re: #12 Quax ICM 1/48 Junkers JU88 A-4 Torp
Post by Les0012 »
Looking forward to this, more so if that squibbly paint job goes on.
Good Luck, Les
An excellent first post from Captain Quax
I too am looking forward to the paintwork on this baby
I wish you good luck and a fun time, welcome to the sig
:cheers2: Scott
Nice choice mate looking forward to this one
Thanks guys, I am NOT looking forward to the squiggly paint but having bottled it on the 1/72nd one I suppose I have to try just to give all and sundry a larf :crazy: :lol:
A bit of data "borrowed" from your favourite open source factoid repository. I have put the link at the bottom so if its wrong go and edit it!
lots of blurb but nice foto at the end so just skip it if you wish.... :think:
Design and development
In August 1935, the German Ministry of Aviation submitted its requirements for an unarmed, three-seat, high-speed bomber with a payload of 800–1,000 kg (1,760–2,200 lb).Design of the Ju-88 began with a study EF59 which evolved into two parallel designs, Ju-85 and Ju-88. The Ju 85 was a twin-engined bomber aircraft prototype, designed by Junkers in 1935. The Ministry of Aviation requested the aircraft, which differed from the Ju 88 due to the use of a twin fin tail unit. The aircraft was never put into service.Design was initiated by Junkers Chief Designer Ernst Zindel He was assisted by Wilhelm Heinrich Evers and American engineer Alfred Gassner. Evers and Gassner had worked together at Fokker Aircraft Corporation of America where Gassner had been Chief Engineer. Junkers presented their initial design in June 1936, and were given clearance to build two prototypes (Werknummer 4941 and 4942). The first two aircraft were to have a range of 2,000 km (1,240 mi) and were to be powered by two DB 600s. Three further aircraft, Werknummer 4943, 4944 and 4945, were to be powered by Jumo 211 engines. The first two prototypes, Ju 88 V1 and V2, differed from the V3, V4 and V5 in that the latter three models were equipped with three defensive armament positions to the rear of the cockpit, and were able to carry two 1,000 kg (2,200 lb) bombs, one under each inner wing panel.The aircraft's first flight was made by the prototype Ju 88 V1, which bore the civil registration D-AQEN, on 21 December 1936. When it first flew, it managed about 580 km/h (360 mph) and Hermann Göring, head of the Luftwaffe was ecstatic. It was an aircraft that could finally fulfill the promise of the Schnellbomber, a high-speed bomber. The streamlined fuselage was modeled after its contemporary, the Dornier Do 17, but with fewer defensive guns because the belief still held that it could outrun late 1930s-era fighters. The fifth prototype set a 1,000 km (620 mi) closed-circuit record in March 1939, carrying a 2,000 kg (4,410 lb) payload at a speed of 517 km/h (320 mph).The first five prototypes had conventionally operating dual-strut leg rearwards-retracting main gear, but starting with the V6 prototype, a main gear design debuted that twisted the new, single-leg main gear strut through 90° during the retraction sequence, much like that of the American Curtiss P-40 Warhawk fighter. This feature allowed the main wheels to end up above the lower end of the strut when fully retracted and was adopted as standard for all future production Ju 88s, and only minimally modified for the later Ju 188 and 388 developments of it. These single-leg landing gear struts also made use of stacks of conical Belleville washers inside them as their main form of suspension for takeoffs and landings.By 1938, radical modifications from the first prototype began to produce a "heavy" dive bomber. The wings were strengthened, dive brakes were added, the fuselage was extended and the number of crewmen was increased to four. Due to these advances, the Ju 88 was to enter the war as a medium bomber.The choice of annular radiators for engine cooling on the Ju 88, which placed these radiators immediately forward of each engine and directly behind each propeller, allowed the cooling lines for the engine coolant and oil-cooling radiators (integrated within the annular design) to be as short as possible, with integral port and starboard air intakes for cooling the exhaust headers, the starboard inlet also supplying the inlet air for the supercharger.As the outbreak of WW II in Europe approached, by the time Luftwaffe planners like Ernst Udet had their opportunities to have their own "pet" features added (including dive-bombing by Udet), the Ju 88's top speed had dropped to around 450 km/h (280 mph). The Ju 88 V7 was fitted with cable-cutting equipment to combat the potential threat of British barrage balloons, and was successfully tested in this role. The V7 then had the Ju 88 A-1 "beetle's eye" faceted nose glazing installed, complete with the Bola undernose ventral defensive machine gun emplacement, and was put through a series of dive-bombing tests with 250 kg (550 lb) and 500 kg (1,100 lb) bombs, and in early 1940, with 1,000 kg (2,200 lb) bombs. The Ju 88 V8 (Stammkennzeichen of DG+BF, Wrk Nr 4948) flew on October 3, 1938. The A-0 series was developed through the V9 and V10 prototypes. The A-1 series prototypes were Wrk Nrs 0003, 0004 and 0005. The A-1s were given the Jumo 211B-1 or G powerplants.Dr. Heinrich Koppenberg (managing director of Jumo) assured Göring in the autumn of 1938 that 300 Ju 88s per month was definitely possible. Göring was in favour of the A-1 variant for mass production.Production was delayed drastically by developmental problems. Although planned for a service introduction in 1938, the Ju 88 finally entered squadron service (with only 12 aircraft) on the first day of the invasion of Poland in 1939. Production was painfully slow, with only one Ju 88 manufactured per week, as problems continually kept cropping up. The Ju 88C series of heavy fighter was also designed very early in 1940, but kept secret from Göring, as he only wanted bombers.
Dive bomber
In October 1937 Generalluftzeugmeister Ernst Udet had ordered the development of the Ju 88 as a heavy dive bomber. This decision was influenced by the success of the Ju 87 Stuka in this role. The Junkers development center at Dessau gave priority to the study of pull-out systems and dive brakes The first prototype to be tested as a dive bomber was the Ju 88 V4 followed by the V5 and V6. These models became the planned prototype for the A-1 series. The V5 made its maiden flight on 13 April 1938, and the V6 on 28 June 1938. Both the V5 and V6 were fitted with four-blade propellers, an extra bomb bay and a central "control system". As a dive bomber, the Ju 88 was capable of pinpoint deliveries of heavy loads; however, despite all the modifications, dive bombing still proved too stressful for the airframe, and in 1943, tactics were changed so that bombs were delivered from a shallower, 45° diving angle. Aircraft and bomb sights were accordingly modified and dive brakes were removed. With an advanced Stuvi dive-bombsight, accuracy remained very good for its time. Maximum bomb load of the A-4 was 3,000 kg (6,600 lb), but in practice, standard bomb load was 1,500–2,000 kg (3,310–4,410 lb). Junkers later used the A-4 airframe for the A-17 torpedo carrier. However, the variant lacked the undernose Bola gondola for a ventral gun position.
Specifications Ju 88 A-4]
General characteristics
• Crew: 4 (pilot, bombardier/front gunner, radio operator/rear gunner, navigator/ventral gunner)
• Length: 14.36 m (47 ft 2⅞ in)
• Wingspan: 20.08 m (65 ft 10½ in)
• Height: 5.07 m (16.63 ft)
• Wing area: 54.7 m2 (587 ft2)
• Loaded weight: 8,550 kg (18,832 lb)
• Max. takeoff weight: 14,000 kg (30,865 lb)
• Powerplant: 2 × Junkers Jumo 211J liquid-cooled inverted V-12, 1,044 kW (1,420 PS, 1,401 hp) each
Performance
Maximum speed: 510 km/h (317 mph) at 5,300 m (17,389 ft) without external bomb racks or 433 km/h (269 mph) at 4,500 m (14,765 ft) at 14,000 kg (30,865 lb)
• Range: 2,430 km (1,429 mi) maximum internal fuel
• Service ceiling: 9,000 m (29,500 ft) at average weight, without bombs
• Rate of climb: 235 m/min (770 ft/min)
Armament
• Guns:
• 1 × 7.92 mm MG 81J machine gun on flexible mount in front windscreen, firing forward with 1,000 rounds.
• 1 × 7.92 mm MG 81J machine gun on flexible mount in lower fuselage nose glazing, firing forward with 1,000 rounds.
• 2 × 7.92 mm MG 81J machine guns on flexible mount in the rear of the cockpit canopy, firing aft with 1,000 rounds each.[70]
• 1 × 7.92 mm MG 81Z twin machine gun on flexible mount in the rear ventral Bola position, firing aft with 1,000 rounds.
• Bombs: Up to 1,400 kilograms (3,100 lb) of ordnance internally in two bomb bays rated at 900 kg (2,000 lb) and 500 kg (1,100 lb) or up to 3,000 kg (6,600 lb) externally. Carrying bombs externally increased weight and drag and impaired the aircraft's performance. Carrying the maximum load usually required rocket-assisted take-off.
Armament options
• Additional option for a pair of 7.92 mm (.312 in) MG 15 machine guns on flexible "Donut" mountings firing laterally, one on each side of the cockpit canopy.
• A single 13 mm (.51 in) MG 131 machine gun was sometimes used instead of the 7.92 mm (.312 in) MG 81J or MG 81Z machine guns in the A-Stand, B-Stand or ventral Bola positions.
• Aircraft may carry one 20 mm MG FF cannon in the nose for ground attack purposes, with 90 rounds of ammunition, in place of the Lotfernrohr 7 bombsight
• A modification of the Ju 88 A-4, the Ju 88 A-13 could mount the Waffenbehälter WB 81A or WB 81B (firing with 15° downwards deflection) gun pods on the external bomb racks for ground attack duties, each "watering can" containing three 7.92 mm (.312 in) MG 81Z twin machine guns, for strafing enemy troops.
https://en.wikipedia.org/wiki/Junkers_Ju_88
Cant wait to see since I'm building an A-4 too... how are ICM kits usually ? they seem pretty nice but never bought one yet.
Looking forward to this one Paul :th:
Thanks guys, its my first ICM kit so I guess we're gonna find out!
Having looked at the photos there's loads of overspray on the squiggles so I'll be a natural at it :banana: :rofl:
Looks like a cracker mate.
Brave to take on that camo too. Really like the bomber kits with all that canopy and nose glass, it means all the interior work doesn't disappear when you close it up. Nothing worse than not being able to see the goods - ooh err missus :lol:
Thanks Stokesy, were you a scriptwriter for the Carry On films....? :roll: :lol: :lol:
Inbetween glasses of cold Muscadet and entertaining my mother I managed to get a little done on the bird...
It actually goes together quite nicely, the seats are over-engineered really I always envisage the creators going "Hmm this kit needs more fiddly bits in places where it doesn't really count...) they look nice though so I splashed out on seat belts which I await.
A few splodges of Ultimate primer
thanks for looking
RossiM1
Post by RossiM1 »
That looks like a great kit some really nice details there, look forward to see you tackle that paint job , rather you than me, good luck with that one mate .Great start and look forward to seeing this progress.
Gary aka RossiM1
Really nice details on those ICM kits !! Should try to buy one for myself ! But hard to find except on internet where I live. Good work !
Very very nice indeed.
I have my pop corn. :pop:
Looks like there's a battle of the 88's
Thanks for the kind words its been good fun so far with no major issues discovered....yet
The seatbelts and mask arrived so I've been able to push on
Then it was on to finishing the cockpit and getting the two halves together
The sharpeyed amongst you may have noticed some wing bits but they’re for the next exciting instalment!
cheers
That looks great Paul, nice progress :thumb2:
Excellent intro information as well :th:
Last edited by Twokidsnosleep on Mon May 14, 2018 7:28 pm, edited 1 time in total.
Looking great so far. Following with interest. My mozzie will be in primer soon so not long before I can join the Ju88 Staffel.
Les0012
Post by Les0012 »
Looking great
Les
Nice cockpit detail. :th: :th: :th:
Ahh, your interior just looks fantastic, back to the drawing board on mine :wall:
Door prize draw coming up this weekend :banana:
Great work on the detail mate
I liked your 1/72 build so I have my eyes on this one too. :pop:
Thanks guys for your kind and completely undeserved comments
This has been a swings and roundabouts process with the occasional desire to stamp into the dirt….
First I shall explain the installation of the engines into the nacelles and their attachment to the wings
One nacelle has the remains of an engine and an awful fit, the other nacelle has the front cut off the engine for the prop with the rest left out and the fit to the wing was much better, I did however have to cut the lugs off on one side where it fits into the underside of the wing.
:bash: :bash: :bash: :wall: :wall: :think: :crazy: :wall: :pistols: :pistols: :boom:
If you want to see how this should be built I should follow InvalidUsername’s build because he’ll do it properly.
On a positive note I have discovered Perfect Plastic Putty, where have you been all my life you amazing wonderful stuff??
The P masks were great for the price, I’m usually terrible with these pre cut masks but these came off the backing nicely and fit the holes well, the only additional bits required are the yellow bits on the top around the more bulbous bits where P masks supply the frame for you to fill with Maskol of suchlike
A good sousing of Ultimate grey later I’ve found a couple of gaps to fill but the new love of my life will caress those into shape
And as this is a torpedo bomber, here are the torpedos
I’d like to say that this has been fun so far.
This has been fun so far….
Well she is looking great, despite what she puts you through...that sounds like most women, no?
Keep up the great work :thumb2:
InvalidUsername
New Zealand
Post by InvalidUsername »
Great work on your Ju88!
I'd like to say I could do the nacelle properly on mine, but to be honest, that part of the build has had me worried the day I flicked through the instruction book. So much going on with so many parts, it will definitely be a test.
I think you've done a great job on those nacelles! Keep up the great work!
Got to agree, it looks great so far! :th: :cheers2:
Looking forward to seeing the next bit! :pop:
Fantastic work, I find Perfect Putty is just great but it does seem to go off in the tube quick. :th: :th: :th:
pourquoi61 wrote: Wed May 30, 2018 9:50 pm Fantastic work, I find Perfect Putty is just great but it does seem to go off in the tube quick. :th: :th: :th:
yes you have to put the top back on sharpish, store in the standing position and if it dries a bit in the tube. Inject some water, top back on and swish the tube a bit to mix the water in.
digger303 wrote: Wed May 30, 2018 11:17 pm
Great tip there Digger many thanks! :bow::
Many thanks also to the kind comments, I'm going through a dose of mojoitis at the moment but I'm off on hols next week so hopefully that will cure it
Cheers mate I will do that from now on. :thumb2: :thumb2: :thumb2:
Looking great. Looking forward to the camo scheme.
Following along with great interest.
Superb work Paul and great save on those pesky nacelles too, it's looking very tidy indeed! :clap:
demarcation
Post by demarcation »
Great work so far!! :th:
//Anders
Les0012
Post by Les0012 »
Agree with all the comments, this is coming on in leaps and bounds
Les
Thanks guys, eating and drinking til near explosion point here on Fuertaventura is doing wonders for the mojo although it may take a while to sober up to start again :crazy: :wtf: :whistle: :lol:
:cheers2: literally...
Quax wrote: Wed Jun 06, 2018 8:39 pm Thanks guys, eating and drinking til near explosion point here on Fuertaventura is doing wonders for the mojo although it may take a while to sober up to start again :crazy: :wtf: :whistle: :lol:
Have a wonderful vacation...looks like a beautiful spot you chose
I had to google where Fuertaventura was mind you. Gorgeous!!!
Recharge your batteries in the sun :D
Drinking, eating, holidays ......................no no no that's not right back to the bench my friend you know dam well all the jollity is bad for you :dance: :cheers2: :cheers2: :cheers2: :cheers2: :pop: :pop: :pop: :pop: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Enjoy mate great work on the 88 by the way :th: :th:
You're on holiday?!?!?! Who approved that!!!! :eeek:
Does General Twokids know about this!??!?!
Tomcat64 wrote: Fri Jun 08, 2018 2:49 pm
Yes and I am upset
I have seen no bikini pictures at all :(
Check you pm's, I couldn't post in the open as children might see :shock: :nena:
Quax wrote: Sun Jun 10, 2018 6:26 pm Check you pm's, I couldn't post in the open as children might see :shock: :nena:
sharing is caring !
digger303 wrote: Sun Jun 10, 2018 11:19 pm
sharing is caring !
I am slightly apprehensive to check...what with Dan’s beach photos on the live show
Twokidsnosleep wrote: Mon Jun 11, 2018 3:28 am
sharing is caring !
always miss the live show. But your the designated scout :lol:
Quax in a bikini??? :eeek:
Tomcat64 wrote: Mon Jun 11, 2018 5:27 pm Quax in a bikini??? :eeek:
OMG ! :violin:
@Tomcat – I did look for a picture of a man in a bikini to insert but they were all just too disturbing for a family channel. I did save all the links so if you want them just send me a pm :oops: ;)
Just to bring things up to date
I have used a (slightly) unorthodox RLM 76 for the underside (because I don’t like RLM 65….) and this was Mission Model Paint as was the RLM 71 on the top. The RLM 70 is Vallejo MA and I think it’s a bit too dark to be honest but hey ho. It’s since been Alclad 2 varnished twice for decals which will be next as the Wellenmuster will go over the top. I’ve decided that as this is a learning curve I’m going to use Mr Paint RLM 76 for the top squiggles and their RLM 71 for the bottom, it’ll be a first time with a lacquer type paint so will it be :banana: or :pray:
The observant amongst you will also notice the missing machine gun, I managed to push this back into the cockpit whilst taking off the last bit of masking tape :cry: :shock:
This was difficult to photograph and get the colours to show so apologies for the distinctly poor quality
Thanks for looking
The paint looks very smooth...nice !
maybe a bit of super glue on a toothpick can pull the gun out ?
no chance unfortunately due to an ominous rattle..... I do, however, have a spare that I'll just have to cut the breech off of and insert but I'll do that last thing.
cheers
Quax wrote: Mon Jun 18, 2018 8:27 am @Tomcat – I did look for a picture of a man in a bikini to insert but they were all just too disturbing for a family channel. I did save all the links so if you want them just send me a pm :oops: ;)
I'll give that a miss thanks mate - Nurse says I shouldn't get over stimulated :lol:
Back to the plot - nice work on the paintwork on that, as Digger says it looks really smooth.
Hope you manage to figure out a way of rescuing the gun back out too.
demarcation
Nice paint job!! :th: :th:
//Anders
