Update 4:
Well, it been a while since the last update for two main reasons: 1 - life (need I say more) and 2 - I stumbled on to some difficulties with this build that have taken some time to to get past. Well, I think I see the light at the end of that tunnel; more on that in a bit...
At the last update I'd finished putting the main assembly together and was getting ready to paint a few small bits (mainly the air scoop assembly) so they could be attached before painting the entire body. They got painted and assembled, during which time I also worked on cleaning up the body so it would be ready to paint. As you can see here, the fit of the bottom section wasn't great. I'm not sure if it was the kit or me, but you can see the worst of it back near the tail; the other side had issues, but not nearly this bad.
Update 4 by
Bob Mortensen, on Flickr
Since there weren't any really large gaps/holes to fill, I used my go to bondo Glazing and Spot Putty thinned with Tamiya Lacquer Thinner. I applied it fairly thick with a disposable Micro-Brush and let it dry for a day or two. After sanding it looks real good, but I'll hold off declaring victory until primer is on!
Update 4 by
There were also some minor gaps at the wing roots, these where filled with Perfect Plastic Putty thinned and smoothed with water. I chose PPP for this since it is a more difficult area to sand and I knew that even after drying for a few days it would be easy to smooth the PPP with a little water. In this photo you can see the filled wing root as well as the filled seam along the top of the cowling. You also get to see how I've masked the cockpit with "white" tack.
Update 4 by
After that, I finished prepping the body (including some rescribing) and prepared several of the other miscellaneous parts (mostly landing gear) for paint.
Update 4 by
Update 4 by
In the last update, I also mentioned needing to figure out how I would tackle the canopy. Well, during the above, things went south fast! It started when I tried creating masks for the canopy using some tape I had not used before. At some point in that process I needed to peel off some of the tape and noticed it left a residue behind. Well, I immediately decided to not continue with that tape; removed it all and attempted to remove the residue... Well, I picked the wrong thing to try to remove it and totally crazed/fogged/ruined the canopy!
Well, that's OK, I had two things going for me. First, Airfix includes two canopies, one for the open position and one for the closed position; I still had the "closed" canopy to fall back on. Second, was the internet! I really wanted the canopy open and while it isn't clear what the difference between the two are, the closed canopy just didn't sit right in the open position. So I thought maybe I would just use the internet to figure out if I could salvage the open canopy. Well, I saw how others have sanded and polished canopies with success so I proceeded to do that. Sanding went well and up to the finest polishing stick I had it was looking good. But some of the inside had been damaged and the outside really needed more polishing. Well, being impatient and cheap as I am, I didn't bother to get the right supplies to do a proper polishing. Instead I tried a few home remedies, including toothpaste. I wasn't getting the results I was hoping for and in the process I managed to create a few minor cracks that pretty much ruled out salvaging this piece.
OK, on to the closed canopy. Did I mention I wanted the canopy open? The closed canopy sort of fit in the open position and if forced down it seemed OK. Well, I guess I just needed to spread it out a bit. I think I've read about people using hot water to soften the plastic enough to reshape it... I'm game. My hottest tap water didn't seem to have much of an effect. OK, boiling water. I'll dip it for a few seconds, it'll be OK. Nope, not enough, a few seconds more... Nope, more... OK much more... There! It seems to have moved... Great... Oh wait, there isn't supposed to be a big bend in the bottom frame! Arrrgghhhh...
Two down, now what. Oh yeah, I heard that Airfix is really good about replacement parts. Internet to the rescue again. I contacted the US spares department and they got back to me within two business days... no sparse available.
Now what? This time Amazon to the rescue!
Update 4 by
Yep for a mear $5+ (and another $20 in other "necessities" to fill out the order and get free shipping) I now have two more canopies to screw up! This is my first introduction to Squadron vac-u-form canopies, I hope they treat me well!
After carefully cutting one out and sanding the edges, things finally started to head in the right direction. The next decision was how to mask for painting. The vac-u-formed canopy's "details" are pretty subtle so creating a mask was going to be difficult. I decided I'd try a variation of bare metal foil masking as described so well by Paul Budzik in one of his videos (for those not familiar with Paul, look him up; he is a master and a great teacher).
I started by filling the interior with "white" tack for some stability. Then, so that I could see the framing better, I cut thin strips of Tamiya masking tape and covered the framing. (Excuse the "white" tack in the photo; it is no longer white and full of lots of paint, dust and debris; but it still works!)
Update 4 by
Next, for the bare metal foil I was too lazy/cheap to go to the hobby store to get the real stuff. We have aluminum foil in the kitchen and I found some cheap low tack spray in the closet; Paul mentioned in his video that that should work. Hmm... only "heavy duty" aluminum foil in the kitchen; sure, why not. I was able to cover the main canopy and moved on to the front; that wasn't going so well, but I was making it work. I then started trimming out the framing which was also going well. I was nearly finished when I noticed that the foil wasn't really sticking that well! Argggghh!
But I was pretty happy that it was at least working! I guess the cheap spray adhesive was indeed cheap and/or old.. It really just set too fast. It also left a residue, which this time I cleaned more carefully with mineral spirits; that worked out just fine.
At this point I wasn't going to give up. I could either go out and get some new adhesive and standard aluminum foil or, wait, REAL BARE METAL FOIL FROM THE HOBBY STORE! So off to the store...
Update 4 by
As you've probably guessed, this went on much easier!
Update 4 by
And after a little trimming, it's ready for paint!
Update 4 by
It's not perfect by far, but seems to be the best I've done yet; only time will tell.
Now finally, on to the paint! Hopefully the next update won't be too far off.
Thanks for looking in!
