Panzer III with SIG 33
All your builds here...
hansolo
Post by hansolo »
Hi guys,
My entry for this GB is of course a conversion!
Here is some info on the vehicle:
Troops are very resourceful and often make battlefield modifications to existing equipment. One such example was the 15cm sIG 33 L/11(Sf) auf Fahrgestell Panzerkampfwagen III Ausf.H (Sf). Only one was ever made and it did not survive the war. Luckily photographs are available to prove its existence.
A Panzer III Ausf H tank chassis was used to mount the same 15 cm s.I.G. 33 L/11 heavy field howitzer that was used on 15 cm sIG 33 auf Fahrgestell Panzerkampfwagen II (Sf) that had an extended Panzer II tank chassis.
15cm sIG 33 L/11 auf Fahrgestell Panzerkampfwagen III Ausf.H (Sf)15cm sIG 33 L/11 auf Fahrgestell Panzerkampfwagen III Ausf.H (Sf) in a ‘hull down’ position. Photo:Eckbaustein
As with it’s baby brother this self-propelled artillery gun also has a problem with its name (The 15 cm sIG 33 auf Fahrgestell Panzerkampfwagen II (Sf) has wrongly been called the Bison II or the Sturmpanzer II: this started after the war). Some scale model kit companies, military history authors and museums wrongly call the field modification 15cm sIG 33 L/11 auf Fahrgestell Panzerkampfwagen III Ausf.H (Sf) SPG the Bison III. It was never called that during WW2.
It is believed that it was used by the German Afrika Korps Schützen-Regiment.200 (90 leichte Infanterie-Division) attached to the s.I.G Kompanie (Sfl.)708 between 1942-1943 and first saw action in September 1942.
Construction of the 15cm sIG 33 L/11 auf Fahrgestell Panzerkampfwagen III Ausf.H (Sf). Photo:Eckbaustein
Why was it built?
In 1941 Field Marshal Erwin Rommel needed heavy artillery to support his advancing armored divisions in North Africa. Horse drawn artillery was impractical in the heat of the desert. The logistics of supplying these animals with enough feed and water was a nightmare. Each towed artillery gun would require a team of six horses to pull it.
He demanded a solution be found. A small number of 10.5cm and 15cm artillery field Howitzers were mounted on captured enemy tank and tractor chassis and sent to support the men and machines of the German Afrika Korps DAK. Some were fitted to obsolete German tank chassis like the Panzer I and Panzer II. These tanks were replaced by the Panzer III and Panzer IV as they came off the factory production line and entered service.
These self-propelled German artillery guns are some times referred to as ‘Rommel’s Funnies’. This vehicle was not designed to advance towards heavily fortified gun emplacements and blow them up whilst under heavy fire. It has only a thinly armoured fighting compartment: the crew have very little protection. It was intended to keep up with the advancing infantry and tanks but remain behind them out of harm’s way and fire shells over their heads at enemy targets.
Heavy lifting gear was needed to fit the 15cm sIG 33 L/11 gun into the Panzer III Ausf.H tank chassis. Photo:Eckbaustein
The 15cm sIG 33 Gun
The Germany Army Infantry regiments could call on the support of a large 15 cm caliber towed artillery field howitzer called the 15cm schweres Infanterie Geschütz 33 (heavy infantry gun). They were designed by Rheinmetall in 1927 and were formally accepted introduced into the German military in 1933, hence the designation 33. This long name was shortened to 15 cm sIG 33 or 15 cm s.I.G. 33. About 4,600 were made between 1936 – 45.
This gun was not designed as an anti-tank gun. It was normally used to fire high explosive HE shells over the heads of advancing German troops at targets plotted on a map. This is called indirect fire. Occasionally it was called upon to fire at enemy positions it could see. This is called direct fire. The two part I Gr 33 HE shell was filled with 8.3 kg (18 lbs) of pressed TNT with smoke box and standard Zdlg. 36 exploder system. The total weight of the fused round was 38 kg (84 lbs).
Unlike anti-tank gun shells that came in one piece artillery shells were loaded into the gun breach in two separate pieces. The high explosive HE shell was always loaded first and this was followed by the propellant cartridge.
The rimmed brass propellant cartridge case, with a c 12 n/A percussion primer was closed at the top by a cardboard closing cap and loaded after the HE shell had been rammed home into the gun. The gun crew had a range chart that told them what amount of explosive propellant to put into the empty brass cartridge case. More was added for longer range targets and less was used to hit targets closer to the gun.
The propellant consisted of six removable silk bags numbered 1 to 6 that contained Nitroglyzerin Blättchen Pulver (nitroglycerin flaked powder) or Diglykolnitrat Blättchen Pulver (diglycolnitrate flaked powder). For long distant targets all six bags would be put in the brass propellant cartridge case. For shorter distances fewer bags would be used.
The gun could also fire smoke rounds to cover the retreat or advance of an infantry or armored column. These shells were called 15-cm Igr. 38 Nebel and weighed 38.50 kg (85 lbs) These smoke shells were identified by the white letters ‘Nb’ on a field-gray projectile. The bursting charge consisted of picric acid, and the exploder system comprised of a detonator set in penthrite wax enclosed in an aluminium container. The shell produces a smoke cloud 50 meters (55 yards) thick.
It had an effective firing range of 4.7 km – 4,700 m (2.89 miles – 5,140 yd). When firing HE shells it had a muzzle velocity of 240 m/s (790 ft/s). A good gun crew could fire three rounds a minute. The shell fuze s.Igr.Z. 23 was a highly sensitive, nose-percussion fuze with an optional delay of .4 second. It operated on impact or graze. It fired two types of HE shell, the 15cm I.Gv.33 and the 15cm I.Gv.38. For all practical purposes they were identical.
The breach was a horizontal sliding block. The gun’s recoil was controlled by a hydropneumatic chamber. The gun was made by a number of different companies: Rheinmetall, AEG-Fabriken, Bohemisch and Waffenfabrik
The gun cradle is situated below the gun barrel. It is trough-shaped and is provided with guide ways, in which guides on the gun move as it recoils and runs out. On either side at the front is a pad to receive the unabsorbed force of run-out, and between them is the expansion chamber which receives the buffer fluid forced from the buffer by expansion as it becomes heated. Towards the rear are the two cradle arms to which the trunnions are fixed. Each trunnion is provided with a cranked compensator lever which compresses the compensator spring.
15cm sIG 33 L/11(Sf) auf Fahrgestell Panzerkampfwagen III Ausf.H (Sf) in indirect fire mode
Gallery
15cm sIG 33 L/11(Sf) auf Fahrgestell Panzerkampfwagen III Ausf.H (Sf) with the gun in indirect fire mode in North Africa 1941. Photographer:
unknown
The crew of the 15 cm s.I.G. 33 B (Sfl.) auf Fahrgestell Pz.Kpfw. III Ausf. H relaxing in the North African desert.Photographer: unknown
If you look at the rear of the vehicle you will notice a metal frame. This was designed to enable boxes of ammunition, supplies and equipment to be strapped to it. Photo:Eckbaustein
You can see in this hull down photograph how the kit was stored on the back of this SPG. Water and fuel cans were put in the rear rack and spare bogie road wheels were fixed to the engine hatches and covered by the foul weather tarpaulin. Photo:Eckbaustein
Why was only one built?
When vehicles get damaged on the battlefield they are recovered by the engineers who try to repair them back behind the front line. Some times parts of an armoured fighting vehicle are damaged beyond repair but the rest of the vehicle is in good working order. The Afrika Korps engineers had problems getting replacement parts in North Africa because of the sinking of Axis transport ships in the Mediterranean by the Allies.
Rommel’s forces were out numbered by the Allies in North Africa who had more tanks, artillery guns and armoured fighting vehicles. The German engineers were under pressure to repair to get as many serviceable fighting vehicles to the front line as they could. It wold have seemed logical to them that a working 15cm s.I.G heavy infantry gun salvaged from a knocked out self-propelled gun should be sent back to the front on a new chassis. In this situation they used a turret less recovered panzer III Ausf.H tank chassis. Development of the 10.5cm ‘Wespe’ self-propelled artillery infantry gun was already started back in Germany. This took priority.
Specifications
Dimensions 5.41m x 2.95 x 2.44 m (17’9″ x 9’8″ x 8’0″ ft.inches)
Total weight, battle ready 20.3 tons
Crew 5
Propulsion Maybach V12 gasoline HL 120 TRM (220 kW) 300 bhp
Speed on /off road 40/20 km/h (25/12 mph)
Armament 15.cm (5.9 in) leFH 18 howitzer 7.92 mm Maschinengewehr 34 machine gun
Range 165 km (102 mi)
Total production 5774
Sources
German Infantry Weapons – US Military Intelligence Service, Special Series No. 14, May 25, 1943. U.S. War Department
Allied Expeditionary Force German Guns – Brief Notes and Range Tables for Allied Gunners – SHAEF/16527/2A/GCT July 1944
Chamberlain, Peter, and Hilary L. Doyle. Thomas L. Jentz (Technical Editor). Encyclopedia of German Tanks of World War
A Complete Illustrated Directory of German Battle Tanks, Armoured Cars, Self-propelled Guns, and Semi-tracked Vehicles, 1933–1945 – Arms and Armour Press
Again I was a little hasty with buying, because when reading the info, I saw only one ever saw action. And that was in africa!
Not much winter there!
But what the hack; I'll make it a "whet if" it was to have served on the eastern front.
So my version will be with dunkel gelb and green camo. And on top of that winter camo. And Winterketten!
These are the kits that I bought:
And some burnishing fluid.
The kit contents:
I started the build with the Sig 33
In the pictures below you can clearly see what part of the gun is used and what they left or cut off.
So I will have to cut off the rear end of the guns foot lateron.
Another nice picture of the vehicle. Apparently it was quite soggy there. It's almost a pillbox!
I also started on some dio stuff. A little country house. Made some molds with a 3D printer.
The walls are going to be of plaster and the roof tiles will be plastic.
Two plaster wall parts drying.
That's it for now folks.
Next up: buildng the P3.
Hansolo
Re: Panzer III with SIG 33
Hi Hans another interesting project where do you find them, I have never heard of ‘Rommel’s Funnies’ until now, something to look up,but I did find this.
Rommel's Funnies: Pz. Sfl. II - 7.5 Cm Kan. L/41 Auf Zgkw. 5t (HKP902), 7.62 Cm F.K.(r) Auf Gp. Sfl. (Sd. Kfz. 6/3), 15 Cm S.I.G.33 B Sfl., Lg.s.F.H.13 (Sfl.) Sfl. Auf Lorraine-Schlepper, Landwasserschlepper
Thomas L. Jentz
Darlington Productions, 1997 - Armored vehicles
Good luck with the build.
hansolo
Post by hansolo »
privatepete wrote:Hi Hans another interesting project where do you find them, I have never heard of ‘Rommel’s Funnies’ until now, something to look up,but I did find this.
Thomas L. Jentz
Thanks Pete! I never heard of them before either. Good term though! Hobart's counterpart.
Apparently I did build some of the funnies, without knowing the term.
Here's one:
And this one:
This one's awesome too. Not mine. Might be interesting to build! :banana:
Thanks for this input, Pete! :th:
Hansolo
AdamLuscombe
Post by AdamLuscombe »
Interesting build! :th:
Dragon
1/35 Jagdpanzer IV L/48
Italeri
1/24 Ford Escort Mk. II
hansolo
Post by hansolo »
AdamLuscombe wrote:Interesting build! :th:
Thanks Adam!
Hansolo
hansolo
Post by hansolo »
Darn. Just found out that the Sd. Kfz. 6/3 already exists as a kit! From Bronco. :roll:
Hansolo
hansolo
Update
Post by hansolo »
Hi guys,
No P3 yet but more work done on the dio and the gun.
Looking at the reference images, I saw that part of the gun's under carriage is cut off to fit it better in the P3.
So I cut it off too.
The cast of the house front. With flattened surface.
The cast of the house front and the gate out of the molds and cleaned up.
Bricks drawn out on the cast of the gate part.
Carved out with a piercer.
The setup.
I made the doors and shutters from a combo of plywood en balsa wood.
Shutter hinges are made of ps-plate.
Doors and shutters completed.
That's it for now folks!
Next up: More dio or P3...
Hansolo
Hi Hans, I'm running out of words to describe your work :jd:
:clap: uitstekend :clap:
spock1701
Post by spock1701 »
Great build so far, hans! That gun is going to look good in winter camo. Nice work on the dio as well. Looks fantastic :jd:
hansolo
Post by hansolo »
Thanks guys! :bow::
Hansolo
hansolo
Update
Post by hansolo »
Hi guys,
I started building the Panzer III.
First up: the wheels.
The suspension.
Lower hull completed.
Gave the Friul Winterketten a burnishing bath and started assembly..
I love that burnising effect. Almost no further weathering required.
Dry fitted the tracks for length.
The upper hull.
I had to cut several parts of, in order to accommodate the Sig 33.
I closed the back of the interior off with plate and laid down a floor of plate and on top of that the metal look relief plate.
I couldn't find any images or explanation of how the gun would be elevated for sitting at the appropriate height on the chassis.
So I build a steel rod frame which might have been constructed to accomplish this. Though I might be totally of here...
Back and sides of the super structure completed.
Frontal armour completed.
Images of the real vehicle showed that there is no machine gun placed through the frontal armour plate. So I closed that off.
I constructed the box to go onto the right side of the super structure.
Added the tools on the left.
Finished constructing the building. Added the 3d-printed roof tiles and 3d-printed rain barrel.
Next up: scrap building some stowage to go on the back of the vehicle
and maybe some more work on the dio...
Hansolo
StarFar
Post by StarFar »
Tracks look really amazing! Also the gun and the new armor.
hansolo
Post by hansolo »
StarFar wrote:Tracks look really amazing! Also the gun and the new armor.
Thanks mate! :th:
Hansolo
hansolo
Post by hansolo »
privatepete wrote::clap: uitstekend :clap:
Dank je, Pete! :thumb1:
Hansolo
SergioSolo
Post by SergioSolo »
Amazing attention to detail! :jd:
hansolo
Post by hansolo »
Sergiotron wrote:Amazing attention to detail! :jd:
Thanks Sergio. :bow::
Hansolo
What he said!
hansolo
Post by hansolo »
What he said!
Thanks Stokesy!
Hansolo
panzerman825
Post by panzerman825 »
Awesome job on the self propelled gun conversion. Nicely built upper armor casement. Scratch built building is fantastic as well.
Bill
hansolo
Post by hansolo »
panzerman825 wrote:Awesome job on the self propelled gun conversion. Nicely built upper armor casement. Scratch built building is fantastic as well.
Bill
Thanks Bill! :)
Hansolo
hansolo
Update
Post by hansolo »
Hi guys,
Small update here.
I finished adding the stowage.
I used bandage gauze for the camouflage netting roll. Soaking it in water diluted white glue, in order to make it keep it's shape when dry.
For tarps I used toilet paper, treated in the same fashion.
To push 'n shape the wet paper into it's desired form, I used wet que tips, so the paper wouldn't tare.
The completed stowage. I added more paper tarps, a bag and a roll. Some boxes and stuff.
The barbed wire is made from one line cut out of a mosquito net.
That's already it for today.
Next up: Some painting or work on the dio.
Hansolo
spock1701
Post by spock1701 »
That stowage looks super. I've been looking for a DIY alternative to camouflage netting, too. Interesting idea, the gauze
Looking good and the barbed wire made from one line cut out of a mosquito net is :crazy: . :th:
hansolo
Update
Post by hansolo »
Hi guys,
Did some painting on the P3.
Black primer.
Base coat of Dunkel Gelb.
The camo colors.
Decals and detail painting.
Gloss coat.
Ultimate Dark wash.
Cleared off.
Matt coat.
Hairspray.
Tamiya white winter coat.
Chipped with brush and water.
My tool for making little paint chips the easy and fast way.
Detail painted and dark washed the stowage.
Dry painted and finished the stowage.
That's it for now, folks.
Next up: Oil paint rendering. :banana:
Hansolo
SergioSolo
Re: Update
You're doing an amazing job! Really inspiring :clap:
hansolo wrote: Image
I love this picture. Looks very realistic, like if it just rained and everything is wet :jd:
That's an amazing build of a really unusual subject - phenomenal work especially the speed you've progressed with it :jd:
hansolo
Post by hansolo »
Thanks guys! :th:
Hansolo
hansolo
Update
Post by hansolo »
Hi guys,
Oil paint rendering on the P3.
First I added small highlights to the white wash.
Some yellow and light brown filtering.
Pin washing and darker areas.
Grime and rust on the interior.
Did some mud with pigments.
First I moistened the sides. Then sprinkled the pigments on. To make heaver mud in the lower areas, I wetted those again and sprinkled more pigments. To give those parts a remaining moister look I used slightly darker pigments there.
More work is also done on the dio.
I started with the gate.
Primed it with black and base painted with different shades of grey.
With Vallejo washes I made the color variations. And dry brushed some highlights with acrylics.
Painted my 3D-printed barrel.
First primed with black.
Then the base colors.
Did the wood effect with brown and black washes. And the metal bands with metal powder.
I filled the barrel 3/4 with water. That is with this resin-water.
Later on I plan to weather the top of the water to mimmic ice.
Primed the house with grey and used hair spray to chip the next layer of white.
White applied.
And chipped.
Door and windows painted.
I made the ground of my dio with my good ol' dirt-glue-water mix.
After applying the mixture dipping with and old brush, I sprinkled dry dirt on top to get a 'dry look' and not a muddy one.
Dry fitted the house an' barrel on the sandy base.
That's it for today, folks.
Next up: More work to do on the dio and the P3.
Hansolo
Wow - that's fantastic progress! I feel like I'm moving at the speed of continental drift by comparison - and your dio is definitely behaving itself much better than mine has :D
Quick question about the rust effects you've used on the interior - did you just use dry pigments in there or did you wet them up (or do something else entirely)?
hansolo
Post by hansolo »
Tomcat64 wrote:Wow - that's fantastic progress! I feel like I'm moving at the speed of continental drift by comparison - and your dio is definitely behaving itself much better than mine has :D
Thanks!
For the floor I used Vallejo and Mig washes. For the effects on the gun I used Oil paint rendering. :th:
Hansolo
Cool - thanks mate!
hansolo
Update
Post by hansolo »
Hi guys,
More work done on the dio.
I made a road sign from cocktail stick, balsa wood and print.
I copied it off of a photo. I set it up in Illustrator with some boxes and some typefaces.
Here's what it looks like in Illustrator.
I glued the printout on the balsa wood.
And cut out the pieces.
And stuck 'm on the stick.
I forgot to take a picture of the painted and weathered result. That's later...
I bought this kit of figures to go on the dio.
Assembled.
Ready for paint.
I only used 3 of the set and added another one.
Primed.
Base colored.
Painted.
Gloss coated for the wash.
Ultimate Wash applied.
Cleaned up with some q tips.
Flat coated.
Weathered with washes and oil paint.
Made some chop wood from branches to go in front of the house.
Glued the blocks together with white glue on some tape to stop them from sliding.
Made an emaille sign for the wall from printout glued to thin PS and glossed with gloss coat.
Made a fence from balsa wood.
That's all for now, folks.
Next up: more work on the dio.
Hansolo
Fridgy
Post by Fridgy »
Holy crap... looking at your build makes me feel like a 7yr old again
You have some serious skills Han :clap:
Mick
WIP: 1/12 Bandai BB-8 & R2-D2
hansolo
Post by hansolo »
Fridgy wrote: Mon Feb 06, 2017 11:57 am Holy crap... looking at your build makes me feel like a 7yr old again
Thanks Fridgy! :bow::
Hansolo
Great work on all those dio bits - love the axe on the chopping block - lovely touch!
:clap:
hansolo
Post by hansolo »
Tomcat64 wrote: Wed Feb 08, 2017 3:42 pm Great work on all those dio bits - love the axe on the chopping block - lovely touch!
:clap:
Thanks Tom! :th:
Hansolo
Bissyboat
Post by Bissyboat »
Fantastic progress. Lots of cool stuff that grabs your eyes. :th:
Where`s my dinghy?
hansolo
Post by hansolo »
Bissyboat wrote: Wed Feb 08, 2017 10:45 pm Fantastic progress. Lots of cool stuff that grabs your eyes. :th:
Thanks Bizzy! :th:
Hansolo
SergioSolo
Such an inspiring work! :clap:
hansolo
Post by hansolo »
Sergiotron wrote: Thu Feb 09, 2017 1:48 am Such an inspiring work! :clap:
Gracias! Sergio. :th:
Hansolo
hansolo
Update
Post by hansolo »
Hi guys,
I made a gutter for the house out of PS plate and balsa wood.
First off the PS plate inner part representing the zinc.
Covered the outside with salsa wood.
Painted the PS grey.
Gave it a zinc look with white oil paint.
Tinted the wood with brown wash.
Gave it the old wood look with a white wash of oil paint.
And installed it into it's place.
Gave my fireplace wood stack a nice place on the dio.
The finished road sign in place.
Made a drainpipe out of sprue.
Painted grey.
Weathered with white oil paint and brown and yellow washes.
And installed.
Redid the mud on the dio, because it was to flat and dry looking.
I those for a more loose muddy look with tracks of the P3 showing.
Added some grass here and there and planted some small trees.
And here's the dio before snowing commences...
Next up: The final touches on the P3 and it might have been snowing... 8-)
Hansolo
Bissyboat
Post by Bissyboat »
I´m gob smacked. Incredible level and fantastic workmanship on the dio. There´s so much here that grabs your eye. No doubt when the tank comes rolling in, it will be even more spectacular. :thumb2:
Where`s my dinghy?
Fridgy
Post by Fridgy »
Bissyboat wrote: Sun Feb 12, 2017 11:00 pm I´m gob smacked. Incredible level and fantastic workmanship on the dio. There´s so much here that grabs your eye. No doubt when the tank comes rolling in, it will be even more spectacular. :thumb2:
What he said :thumb1:
I can only wish I can get to this level one day
Mick
hansolo
Final Update!
Post by hansolo »
Hi guys,
It has been snowing!
You can see the final reveals here: http://www.intscalemodeller.com/viewtop ... 83&t=21513
Hansolo
Les
Post by Les »
Congratulations on your finish! :cheers2:
Return to “Build Threads”
