A mock up of what's done so far:
The cargo cover is in it's final colour already simply because I got the urge to spray some paint, without it:
The plan was/is to get the frame and running gear together so that I would have the final height of the frame, which would allow me to figure out the way to attach the plow. As the plow isn't meant for this kit/vehicle and there are some differences that will have to be dealt with, for example, the kit/vehicle the plow is meant for is has the front bumper fully exposed, where one this one the hood (bonnet) and grill extend out right over the front bumper and guess where the plow attaches....
Anyway, the plan was to put together the least amount possible (to avoid breakage) and get the mounting plate onto the bumper and then keep the rest of the plow apart until much later (again, breakage). In order to do that the hood and engine bay sides have to go on, but in order to place them the cab has to go on first (the cab has well defined mounting points, but none of the parts in front of it do, they mount of off the cab, so more breakable parts have to go on....
I'm not closing up the cab until the interior paint is done and the glass has gone in, which will be much later:
And not only did the back of the plow get a bit of damage in transport (the the video), but one of the four rods that connect between the plow and the plow mounting plate:
So I'll have to fix that soon.
Now, while all the parts are numbered, the sprues aren't lettered (might be the Italeri heritage showing?) so to save looking and the sprue map every 2 minutes and loosing my sanity:
