Can anyone give me some advice on what I should use to cut resin? I've seen a few videos where a razor saw is used, so is that the best tool to use? If so, which razor saw should I get? Not looking for anything too expensive, £10 or so.
Thanks in advance
Cutting Resin
Cutting Resin
- MarkVerploeg
- Major
Re: Cutting Resin
For me it depends on the part i need to cut
If it has a large casting block i will use a razor saw
The one i have is from pro edge and is not that expensuve but it isn't designed to work on resin
There are some specialized resin razor saws on the market aswell
And smaller parts with just a thin connection to the casting block can be removed with a normal hobby knife
- Vleugelmoer
- Sergeant Major of the Army
Re: Cutting Resin
Like mark already mentioned a razorsaw is the go to tool for removing medium to large resin casting blocks. For this purpose I have one from CMK that does an excellent job. For making more refined cuts a have a variety of photo-etch blades from Tamiya and RB Productions. I also use these to modify the kit plastic parts to accept the resin aftermarket. One advantage of these blades are that they fit right into an X-acto / Excell style hobby knife handle.
For small parts and removing razorsaw burrs I use a fresh hobby blade suitable for the purpose.
Hope this helps you out.
As always happy modeling and keep sticking styrene and resin.
Paul J (The Other One)
Damm the glue is getting to me
Re: Cutting Resin
Thanks for the advice guys. I see the CMK razor saw is a bit more expensive than I'm looking for. Are the X-acto saws any good? I found this one on emodels https://www.emodels.co.uk/x-acto-precis ... 75300.html
- MarkVerploeg
- Major
Re: Cutting Resin
That looks like the same kind of saw i have
They work but you can't cut small parts with it
- Vleugelmoer
Re: Cutting Resin
Here's the type of saw that works best.
https://www.scalemates.com/kits/267758- ... -p-004-saw
These cam be found around the €10,00 mark with translate to around 7 / 8 quid. In your LHS.
A good root down the bargain Web stores could get you some bargains, as do modelshows
- Vleugelmoer
Re: Cutting Resin
ElCapitan wrote:Thanks Paul, I've just ordered one from Czechia on eBay.
- schweinhund227
- Chief Warrant Officer 4
