So with my first 2 figures finished it is time for some new ones
With the Luz figure in the sci-fi build i decided to make another figure but i will put it here in the WIP section as it may take a bit longer to finish
And 1 entry is enough i think
So this time i will be painting this figure
It is Luna's soldier in 70mm or 1/24 scale
Another figure from the Malefic times series
All the parts
The body and head are the biggest part
The detail looks pretty good and i couldn't find and seamlines or airbubbles that needed some attention
One part of the jacket comes as a seperate piece
The right leg
The lower right arm and hand with the sword
And the little base
This has some airbubbles but only on the bottom so those won't be seen
I then glued the figure together
The fit was great and i couldn't find any gaps or seams to fill
So in terms of quality it is very good
Because one foot is on a different step of the base i had to glue a small stick under her foot to have her stand up the right way and make painting a bit easier
I kept the seperate part of the jacket seperate as it is easier to paint this way
Now i can reach the back of her leg easier aswell as the inside of this part
Once the skin and inside of this part are painted i can glue it in place and then i only have the red outside to worry about
I hope to get it primed soon but the last couple of nights it was just too hot at the bench and i didn't want to prime it in case the primer dries too fast and possibly cracks or peels off
I do have a strong sense i made this post before but i guess i didn't hit the submit button as i couldn't find it anywhere
But that wouldn't be the first time that happened to me
Anyway thanks for stopping by and having a look
Untill next time
Mark
