The kit has excellent detail all over and i will likely pose the plane in a diorama landing on the sea
This floatplane version of the F4F-3 was developed for use at forward island bases in the Pacific, before the construction of airfields. It was inspired by appearance of the A6M2-N "Rufe", a modification of the Mitsubishi A6M2 "Zeke". BuNo 4038 was modified to become the F4F-3S "Wildcatfish". Twin floats, manufactured by Edo Aircraft Corporation, were fitted. To restore the stability, small auxiliary fins were added to the tailplane. Because this was still insufficient, a ventral fin was added later.The F4F-3S was first flown 28 February 1943. The weight and drag of the floats reduced the maximum speed to 241 mph (388 km/h). As the performance of the basic F4F-3 was already below that of the Zero, the F4F-3S was clearly of limited usefulness. In any case, the construction of the airfields at forward bases by the "Seabees" was surprisingly quick. Only one was converted.
