So I'm going to be building Tamiya's 1/48 Mosquito FB Mk VI
I'm planing on doing option B which is the Coastal Command varient.
Let the fun begin
Much easier than I thought it would be, certainly much easier than fiddling with tiny pieces of PE. Its a bit daunting though when you start chopping off the original kits parts.how did you find working with resin for the first? time
Was just and idea that popped into my head whilst trying to line up the tiny pieces of masking tape into the correct place, much easier than struggling with two pairs of tweezers.Nice trick with the masking tape. That's one I'll be using next time for sure.
that would make a nice 'simple' dio'das84 wrote:
Coen wrote:Dot filters are one of my favourite weathering effects. It's that little bit of magic that adds so much.
If done right it can make all the difference
That's a super looking build bud. The dot filter will certainly knock the hell out of it![]()
is that roundel a decal? either way awesome job
that's a fantastic effect, I'm going to try that myselfdas84 wrote:Yes the roundel is a decal, even more impressive is its a tamyia decal which has actually done what its supposed to do.
Its been faded a little by drybrushing it with oil paint so that it hopefully matches up with the rest of the worn, sea battered look.
