Thanks Panzerman, I appreciate it.
I know its been a while for and update, so, here goes.
Last weekend I managed to mask and prime the areas that will be yellow and orange in white. Used Vallejo, the first bit of using it came out spitting. Turned up the air and thinned it a bit and that fixed the problem. When the primer had dried the model looked horid! The seam lines stuck out like my bum wrist. (more on that in a bit) Today, I spent the afternoon basically refilling the joint lines and getting it all sanded and shaped back. Gonna let the plastic putty dry good before masking and priming again. I will admit, learning lots from this kit. I need to try and finish this in the next couple weeks. Tore up my wrist a while back, read that as years, and it gets cut on the end of Feb. Will be in a cast 6-10 weeks. Anyway, thanks for looking and the comments.
All masked and ready to hit the booth for primer
Let the patch work begin
Getting there, re-scribing some lines and cutting back the primer and almost ready for re-masking
I had intended to paint in pieces then finish assemble the model. Test fit the stab halves and there was a gap. debated about just leaving it but no, gonna try and do it right. I will just mask off the stab and paint it later. The set on the dihedral came out right tho
No one said it would be easy, only that it would be worth it..
