Hoping my first ISM build goes well, I will keep it quite basic.
The HobbyBoss 1/72 HH-60H Rescue Hawk (Early Version)
Box Art
Instructions: This is my first Hobby Boss kit and the instructions layout was interesting to see but still reasonably easy to follow
Sprue Shots, Not bas detail for a 1/72 kit a few pin marks inside body will check which is visible and remove those. The clear sprues in good condition but not sure how to handle painting the wipers, which are part of the clear molding.
A Little History
HH-60H Seahawk
An HH-60H deploying a SAR swimmer:
The HH-60H was developed beginning in September 1986 with a contract for the first five helicopters. The variant's first flight occurred on 17 August 1988. The HH-60H was developed in conjunction with the US Coast Guard's HH-60J. Deliveries of the HH-60H began in 1989. The variant earned initial operating capability in April 1990.[11] The HH-60H's official DoD and Sikorsky name is Seahawk, though it has been called "Rescue Hawk".[12]
Based on the SH-60F, the HH-60H is the primary combat search and rescue (CSAR), naval special warfare (NSW) and anti-surface warfare (ASUW) helicopter. It carries a variety of defensive and offensive sensors making it one of the most survivable helicopters in the world. Sensors include a FLIR turret with laser designator and the Aircraft Survival Equipment (ASE) package including the ALQ-144 Infrared Jammer, AVR-2 Laser Detectors, APR-39(V)2 Radar Detectors, AAR-47 Missile Launch Detectors and ALE-47 chaff/flare dispensers. Additionally, airframe improvements in engine exhaust deflectors provide infrared thermal reduction reducing the threat of heat-seeking missiles. The HH-60H can carry up to four AGM-114 Hellfire missiles on an extended wing using the M299 launcher and a variety of cabin and port window mounted guns including M60D, M240, GAU-16 and GAU-17/A machine guns.
The HH-60H's standard crew is pilot, copilot, an enlisted crew chief, and two door gunners. The HH-60H is operated by Helicopter Antisubmarine (HS) squadrons with a standard dispersal of four F-models and three H-models. In Iraq, HH-60Hs were used by the Navy, assisting the Army, for MEDEVAC purposes and special operations missions.[citation needed] As the Navy transitions its Helicopter Antisubmarine (HS) squadrons to the MH-60S, remaining HH-60Hs are being transferred to its East and West coast special operations squadrons (HSC-84 and HSC-85, respectively).
Crew 4 - Pilot, Co-pilot & 2 flight-engineers/door-gunners
Engines 2 Two General Electric T700-GE-401-C 1,900 hp engines
Dimensions L - 17.1m W (rotorspan) - 14.1m H - 4.4m
Weights 6,114 kg (empty) 9,967 kg (max loadout)
Max Speed 296 kph
Range 463 km
Armament 2 gun ports (port/starboard) :
7.62mm machine guns/miniguns and/or.50 machine guns
AGM-114 Hellfires
GCAL-50 Gatling Guns
Maverick missiles
70mm FFAR rocket pods
AIM-92 Stingers
Avionics AN/AAQ-16 FLIR
AN/ARN-148 Omega/VLF navigation
M-130 chaff/flare dispensers
AN/ALQ-144 IR jammer
AN/AAR-47 Missile Warning System
Radar / Laser warning receivers
Ring-laser inertial navigation system
Global positioning system
Doppler navigation system
TACAN
KG-10 map display unit
Weather avoidance radar
Automatic flight control system
Potential weathering dream. I will post walkround shots along with progress.
